Adding/Removing HFC vs Test Pipes for emissions.
Old Apr 23, 2009 | 10:36 PM
djcetra's Avatar
djcetra
Default Adding/Removing HFC vs Test Pipes for emissions.
I've been trying to decide whether or not to go with HFC or Test pipes but right now my concern is passing emissions if I were to move back to CA from AZ. From what I've gathered, I would have to rem the HFC or Test Pipe and put back on the OEM cats to pass and then put back on the Aftermarkets.
At this point, my questions are:
Is one more of a pain in the *** to swap out then the other?
I've read that Test Pipes cause the car to smell a lot like gas etc including the driver, how true is this statement? I don't want to smell like gas everywhere I go.
I've read here and there that Test Pipes will give you the biggest gains for the $ but most Test Pipes I've researched weren't much cheaper then HFC's. Others are saying the HFC will give you about the same, are the gains about the same? Also, what about the Check Engine light? I want a solution that is NOT going to throw the check engine light unless the gains are ridiculously higher then HFC and I believe all Test Pipes will throw CEL..
For those of you with HFC, which have you found to be the most reliable and NOT throw Check Engine Lights?
Last, any opinions on HFC & Test Pipes that sound & work great with a Greddy EVO2 Exhaust would greatly appreciated. I do like to have some sort of audible change that gives an aggressive impression but I don't want a solution that will leave my car screaming 10 blocks away sounding like a ricey pos.
Thanks for the help.
Old Apr 23, 2009 | 11:36 PM
sno's Avatar
sno
I have test pipes and went through my emissions test with them still on the car. They just did the computer plug-in test and didn't bother with the sniffer.
The only time I notice the smell is when I first start it up or if I'm really hard on the gas and then abruptly come to a stop (like if my stink cloud catches up to me). No one that's ever gotten in my car has noticed and I certainly don't smell.
Old Apr 24, 2009 | 12:23 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
hummm from my experience..
It's ok
Yes, it is true
Price:
TP = around 200 or less, but i think it's little more expensive if you have the HR motor.
HFC= around 400~600
CEL : I had a CEL with TP, but not with HFC
I've had ceramic and metallic(now) Ultimate racing High flow cat, both of them no issue.
Here is where i got my HFC from www.z1auto.com
Everyone has diff taste..
Hope this help...
Old Apr 24, 2009 | 02:56 AM
djcetra's Avatar
djcetra
Deffinately some good help from the both of you so far. I have a 2006 Enthusiast DE motor so hopefully it won't be as expensive.
I checked out the Ultimate Racing HFC's on z1auto.com, I wonder about the 50 state emission safe claim though. In CA would I fail from a visual inspection or is it possible that I may actually have a chance at getting through the test with these? Perhaps it's just more safe to put the stock cats back on for the test and then reapply the HFC. Opinions?
Old Apr 24, 2009 | 03:19 AM
Passing emissions test depends on what type of test. Some states just check OBDII. Other states may do a visual inspection on a lift. How about checking the the state about requires before making a decision.
Old Apr 24, 2009 | 03:23 AM
Some after market high flow catalytic converters look like the OEM converters. Besides if you do fail emissions what happens? Do you get 90 days to fix the car?
Old Apr 24, 2009 | 08:05 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
They do have ceramic one looks like OEM. Most metallic HFCs has no heat shield, that is why looks little diff.
I'm pretty sure you should be fine with ceramic ones.
Edit: you can use a search botton and put " emission " in ' intake & Exhaust' or you can also try G35driver, they have a many good info.
Old Nov 21, 2009 | 12:10 PM
michaelmyers's Avatar
michaelmyers
Is there some elim for the check engine light if I use test pipes? Thanks
Old Nov 22, 2009 | 11:56 AM
Lee R's Avatar
Lee R
sales@czp
Sep 23, 2019 03:30 PM
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
