Nismo Air Intake Issues--HELP!!!!!
Old Apr 24, 2009 | 05:05 AM
03350ZVA's Avatar
03350ZVA
Smile Nismo Air Intake Issues--HELP!!!!!
Hello all, I'm new to this forum.. I have a little issue. Yesterday I installed my new Nismo cold Air Intake to my '03 350Z and this is the issue that I am having.
1) the car turns on, but after a few seconds it turns off. I sounds like the new intake is throwing off the Air Sensor.
2) So I took off the sensor that connects to the intake and the car starts. But now the check engin light comes on. Then I plug the Sensor back in and gave it a little gas. The could hear the intake working, but it idles weird sounds like it wants to shut off.
3) Then I took it out and tried testing it. The car will not go pass 3000rpm and stalls. I gave it gas but nothing.
Can it be the ECU. DO I need to reset it. If so, please give instructions.
Thanks...
Old Apr 24, 2009 | 06:22 AM
fran914's Avatar
fran914
im currently having the same problem. and cant figure it out
works fine when i put the original system in though ????
Firebase99's Avatar
Firebase99
Manual Method
Here is a quick way to reset your ECU. It is also known to clear codes thrown, and turn off the "Service Engine Soon" Light. It's a little tricky, but works.
Confirm that accelerator pedal is fully released, turn ignition switch “ON†and wait 3 seconds.
Repeat the following two procedures quickly five times within 5 seconds:
Fully depress the accelerator pedal (HARD).
Fully release the accelerator pedal.
Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the CEL starts blinking.
Fully release the accelerator pedal (while the CEL is still blinking)
Wait about 10 seconds.
Fully depress the accelerator pedal and keep it for more than 10 seconds.
Fully release the accelerator pedal (The CEL light will continue to blink).
Turn ignition switch to “OFF†position and now you can start the car. The CEL light should be gone.
http://www.*********.com/zwiki/Tutorial:ECU_Reset
Old Apr 24, 2009 | 06:52 AM
VO...'s Avatar
VO...
Administrator
Moved...
Old Apr 24, 2009 | 07:33 AM
03350ZVA's Avatar
03350ZVA
does this work. Have you done this. Just asking cause I'm about to try it
Old Apr 24, 2009 | 07:34 AM
03350ZVA's Avatar
03350ZVA
I also heard that if I diconnect the battery for 10 minutes and then reconnect and let it run for 15 it should reset everything.
Old Apr 24, 2009 | 11:31 AM
67ZNISMO's Avatar
67ZNISMO
check the MAF sensor...make sure it isn't dirty or backwards (it does happen).
If that doesn't work, try and disconnect the battery to reset the ECU; that's what I did.
Old Apr 24, 2009 | 04:22 PM
NISMO_558's Avatar
NISMO_558
Did you disconnect the battery FIRST, before you started the installation?
Old Apr 25, 2009 | 06:49 AM
HawaiianBBQ's Avatar
HawaiianBBQ
Default CAI problem
That's one of the first steps on the installation manual. If you didn't do this, then reset.
Old Apr 25, 2009 | 08:54 AM
mysmokenz's Avatar
mysmokenz
sounds like the air sensor is installed backwards
Old Apr 27, 2009 | 05:17 AM
03350ZVA's Avatar
03350ZVA
Thanks. I figured it out. It was the sensor. It was installed backwards. Wish I would've read this before signing out...lol I took the Intaked out 3 times. So I decided to put the stock one back on. When I did this, it did the same thing. So my father in-law who was helping me noticed it.... We felt dumb afterwards...
Old Apr 27, 2009 | 05:18 AM
03350ZVA's Avatar
03350ZVA
Oh yeah, the resetting the ECU instruction works. I did it three times.
350Z_Al
Oct 29, 2020 07:44 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
