HFC??
Old May 1, 2009 | 03:19 PM
User 42426's Avatar
User 42426
Default HFC??
I already searched and didn't find anything, if there is please post the link.
I just installed my hks exhaust couple days ago, and i want it to be a little louder. I was reading up on some threads and heard that there were issues with cracking from berk hfc, is this correct? If I were to get hfc, which brand would you guys recommend that would last a long time while still providing increased volume. Also, would like to hear more from hks owners with hfc and which ones you went with.
one more thing, would FI, berk, or crawford produce different sounds? or would any of them provide the same sound? Just looking for increased sound from my hks, not altering the note. Thanks.
Old May 1, 2009 | 04:31 PM
importdemon5's Avatar
importdemon5
I blew my welds on my HFC 2 times. They weren't berks but the welds still blew. I also have my hfcs making a crap load of noise because I busted the resonators in them from extreme heat. Usually takes a while to do that to the cats but why spend $500 to have that happen 8 months later. You are better off getting straight pipes and spending $250 less than the HFCs. Also if you have your stock cats you can throw them back on to pass emissions. The straight pipes are going to be lowder but they will sound good with a bit of the hissing sound, forget what it's called. Since the cats are high flows they are gonna sound good regardless of the type
There are a crap load of threads on the cracking of the HFCs just do a searc of Berk metallic cats or something like that..
Old May 1, 2009 | 04:42 PM
There is a "issue" with reliability of all test pipes and high-flow catalytic converters. Stress cracks, failure of internal material.
Old May 1, 2009 | 05:09 PM
User 42426's Avatar
User 42426
Geez, well that sucks. Is it just the test pipes and hfc's that are prone to cracks? Nothing of that sort will happen to our aftermarkets exhausts, is that correct?
Old May 1, 2009 | 05:25 PM
Unfortunately no. Members report material inside of cat-back exhaust systems (resonator and muffler material) failure. The results is not a function problem, but a noise problem. Rattle, bird-like chirp.
Old May 1, 2009 | 05:32 PM
deleted
Old May 1, 2009 | 09:11 PM
Escobar's Avatar
Escobar
I have berk's hfc and the HKS hi-power exhaust for well over a year now with no issues at all...
Old May 5, 2009 | 07:27 PM
User 42426's Avatar
User 42426
quick question, the only reason for changing to test pipes or hfc's over stock cats is to increase the sound volume, is that correct?
Old May 6, 2009 | 05:35 AM
350junkie's Avatar
350junkie
removes the restriction of the stock cat's. test pipes are ideal but HFC's can still let you pass emissions.
Old May 6, 2009 | 06:21 AM
importdemon5
^^And so do test pipes if they check the OBDII ports and don't do the sniffer test. You just have to buy the CEL fixer bolts, or whatever they are called, I believe titek makes these but you can also just go to homedepot and make your own.
But you don't have to worry bout registration test if you keep the stock cats and put them on when you need to go and get ur car registered again. The cats only take all of 10 min. to take off and another 10 min to put back on.
Old Jun 3, 2009 | 08:29 PM
FTD350z's Avatar
FTD350z
I was wondering too will G35 HFCs work on a 350z? Can anyone pm me the answer to this ive been looking on here and cant find anything? I found a used set of Berks HFCs for a good price and want to do it but not sure if i just want to get test pipes instead. What do u guys think? I have a Borla exhaust incase anyone was wondering
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
AutoStore350z
Mar 13, 2007 06:23 PM
m1james@bellsou
Nov 20, 2006 02:13 PM
dingobiatch
Jul 1, 2006 08:05 AM
350Z_LMS
Apr 12, 2006 05:44 AM
