cosworth intake plenum
Old Jul 19, 2009 | 10:52 AM
OCG35's Avatar
OCG35
Adam, is it fair to say that moderately aggressive cams would be needed?… I have mild JWT S2 and didn’t think I would benefit from the Cosworth plenum (until very high rmp)… _+ I don’t like the idea of losing low to mid trq either…
So, would 256 cams benefit from the Cosworth’s? (I have Crawford headers too)… I hadn’t considered this plenum for NA, but of course I’m not privy to as much research as you apparently have done.
Old Jul 19, 2009 | 11:05 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
I couldn't give an answer as I've got no experience with those.
Old Jul 19, 2009 | 04:45 PM
OCG35's Avatar
OCG35
In theory, and based on your flow bench tests… would a longer duration/higher lift be more advantageous than shorter duration/lower lift cams?
And what cams did you test with?
Old Jul 20, 2009 | 04:52 AM
Z1 Performance
Former Sponsor
As I mentioned, rpm also plays a huge role, and the higher the engine revs, the better the Cosworth shines. I have no idea how that particular cam would interact. You would have to try it and let us know.
All tests have all been done via a flowbench and with a manometer.
Old Aug 6, 2009 | 04:56 AM
TSG-Z's Avatar
TSG-Z
I do like the BLING factor of the Cosworth, but I need some opinions. I'm built bottom end with Nismo cams, Vortech with additional bolt-on's to include the Crawford Plenum. Would I lose power with the Cosworth piece?
Old Oct 23, 2009 | 08:17 AM
35th SS's Avatar
35th SS
Instead of starting a new thread about this, i decided to revive this one since it was the closest thread I could find to get my answer...
I have a rev-up engine and I'm about to buy a Mrev2 + 5/16 combo and then I saw this amazing item... would I be looking at similar gains ( I could only find comparison of both on a regular DE engine not on a Rev-Up )
I will be going for a FI setup once the 2 and 1/2 years left of my warranty runs out that's why i'm really considering this Cosworth intake
Any input, tests, dyno sheets, experiences on a stock rev-up engine would be really appreciated guys
apex locator
Jul 23, 2021 02:27 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
NissanZcrazy
Sep 23, 2015 07:59 AM
_koubie_
Sep 20, 2015 06:34 PM
