Finally found my problem. Rattling exhaust. *Pics
Old Jun 13, 2009 | 04:16 PM
freedonutss's Avatar
freedonutss
Default Finally found my problem. Rattling exhaust. *Pics
For the past few weeks ive been trying to locate this deep rattling/thumping noise. I jacked the car up today and banged on the exhaust and heard the rattle. It was one side of the H - Pipe rattling against some black metal piece. I think its an underbody brace or something but not sure. I attached a picture. Anyways, I tried everything to move the exhaust to the right so it wouldnt rub but with no luck. Any suggestions?
Old Jun 13, 2009 | 06:52 PM
Thanks for the photo. I hate to suggest folding a piece of thermal wrap and stuffing it between the brace and pipe, but you may have little choice.
Old Jun 13, 2009 | 06:56 PM
alwaysliftin's Avatar
alwaysliftin
does it make the rattling noise at like 2k rpm when you decelerating? mine does this and i haven't found a solution yet, i just live with it for now hope you find something
Old Jun 13, 2009 | 07:08 PM
freedonutss
The rattling noise at 2k rpm when decelerating is the flex pipes hissing. Normal when running Test Pipes or HFC.
Davidv you might be right but im gonna avoid taking that path. Anyone know what that black piece is for? If removing it will affect handling or stability ?
Old Jun 13, 2009 | 07:27 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
I've had that happen before. My (temporary) solution was a folded up paper towel between the contact points. I ended up replacing the defective part soon, though.
You can always bang/dent in the piping where it touches the bracing (won't affect anything) or get an exhaust shop to fabricate you a new pipe/piece. As davidv suggested, you can also just wrap it with thermal wrap.
As for the deceleration rasp, I believe that is due to your test pipes and the turbulence of the exhaust gas particles within the piping itself. It can only be remedied through the use of appropriate exhaust layout/design or by putting the cats back on, I think.
Old Jun 13, 2009 | 07:37 PM
freedonutss
The rubbing is very minor, only happens when my car is parked on a hill and on startup. Ill look for some thermal wrap I guess just for a temporary solution. Im looking to replace the Titek test pipes anyways so Ill find something with brackets. Wheres the best place to buy thermal wrap without getting raped on the price? Ive seen some ridiculous prices like $50 per sq ft.
Im loving the numbers in your sig, Im making just a little more power and was hoping to drop down in that range. What wheels were you running on at the time you ran 13.2?
Old Jun 13, 2009 | 07:44 PM
3hree5ive0ero
Retired Admin
Try some of our vendors here first. They should be able to help you out. Look for keywords like exhaust, thermal, and wrap in the vendor classifieds.
As for my N/A time, be sure to compare the dates. My dyno numbers were obtained when I had an aftermarket exhaust (Fujitsubo Super Ti) on top of the 4 performance mods that I ran the 13.2 with.
When I ran the 13.2, I had the popcharger, mrev2, 5/16th spacer, and test pipes. I was running on slicks, Hoosier D05 compound to be exact, that were mounted on Weld Draglites.
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
