Pre/post dynos with Motordyne Shockwave ))) Exhaust
Old Jun 24, 2009 | 08:51 AM
guitman32's Avatar
guitman32
Originally Posted by scotts300
Honestly, hard to say. When I bought it, the "tune" it came with detonated at the high-end from overtiming. I was running 94 octane to compensate for it. Rather than re-tune for the old set-up then RE-tune for the new set-up, we did the 1:1 on 94 octane with nothing else changed, but there were still a few ticks over 6300RPM (with both exhausts). After we made the exhaust change and did the dyno, ZCG pulled some timing to get the detonation in check, and it subsequently made more power. I suppose I don't know for sure if backing off on the timing on the NISMO would have made the same power gains. . .
Thanks for the reply. For 8hp, I was about to pick up the phone and order one of these, as I am running basically your old exhaust setup (Nismo w/Y pipe, HFCs).
Old Jun 24, 2009 | 09:57 AM
scotts300's Avatar
scotts300
Awesome. Remember - my #s are with stock cats installed.
Old Oct 16, 2009 | 01:27 PM
scotts300's Avatar
scotts300
Update:
"Those goals were to make a few extra ponies and lighten the car up a bit for the track and autox."
Original car weight and power (when purchased USED): 3180#, and 250rwhp/237rwtq
After tune (MD [lighter] exhaust, rear gutted, cats installed): 3060#, and 259rwhp/242rwtq
After re-tune (NISMO headers swapped for ported stockers, more weight reduction, test pipes installed): 2920#, 266rwhp/250rwtq, but look at the tq/hp pick-up from 3-5k RPM.
You can read about my reduction from 3180# to 2920# (and not done yet) on the last few pages here: https://my350z.com/forum/engine-and-...your-z-34.html
Old Oct 16, 2009 | 01:53 PM
Motormouth's Avatar
Motormouth
the car sounds great.
I wouldn't have expected the MD exhaust to make more gains if the tune was bad... it kind of sucks the before/after was compromised due to that, but regardless it was an improvement.
Old Oct 16, 2009 | 04:25 PM
gabe3d's Avatar
gabe3d
Those are great numbers Scott. That area at 3-4 got great improvements. Doesn't really matter for you but I wonder what contributed to that drop at 2500. What were your intentions by going back to the stock headers, aren't they heavier then the nismo?
Btw, never asked Rob, but do you know if his dyno runs are ran under load or not?
Old Oct 20, 2009 | 09:54 AM
scotts300's Avatar
scotts300
Thanks! I asked Rob about the slow ramp at low RPM, and he said he likes to apply the pedal smoothly down low rather than just stomp on it. I put the stock headers back on to fund the goodies to make this a safer track car. I forgot to weigh the stock headers, but I bet their weights are within the noise of each other. I spent hours porting the casting marks on them, and given the data available, the NISMO headers on a stock engine don't give much in the way of gains.
As for Rob's dyno, I didn't know that they couldn't be run without being under load. . .His dyno is so new, so I'm sure it follows the same as the other Dynojet Research systems.
Old Oct 20, 2009 | 11:22 AM
gabe3d's Avatar
gabe3d
Thanks for the info, i'm sure those few extra HP gains from the Nismo are completely insignificant compared to how much you lightened your car. Not trying to be the devil's advocate but I don't think it matters if he does apply the pedal smoothly or not, the dyno is plotted over RPM and not elapsed time. I'm thinking it must be related to something else.
Yeah his dyno machine is pretty new and it's a higher model one that allows him to preload or not the machine when performing a test. If I recall correctly he does tune under load but I completely forgot whether the dyno he hands out are in which mode (it seems to me to be under load, but not 100% i'll ask him this week). I'm asking this since it will make a big difference for capturing the effect of rotating mass. I did some testing on a mustang dynamometer with my car and got some pretty interesting results when I lightened my rotors and changed rims.
Old Apr 17, 2010 | 07:24 PM
scotts300's Avatar
scotts300
Updating this thread with new/additional dynos after tuning for ART pipes with Osiris.
Old Apr 18, 2010 | 12:41 AM
gabe3d's Avatar
gabe3d
Nice stuff Scott. Do you think the top end gains was related at all to the switch over to Osiris and some better tuning because of better tuning as well as vtc?
Old Apr 18, 2010 | 05:20 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Scott,
Is it possible you could email me the run files? I can put it into excel for a A minus B plot to bring out the deltas.
Old Apr 19, 2010 | 07:32 AM
scotts300's Avatar
scotts300
Possibly, though I'm not certain. Rob spent a long time tuning the car previously with my test pipes to maximize the power and torque curve. He spent an equal amount of time with the Osiris tune since we were basically starting over.
Originally Posted by Hydrazine
Scott,
I'll ask Rob if he can get the data for those files so we can do the delta plots.
Old Apr 20, 2010 | 01:36 PM
ajcool2's Avatar
ajcool2
Nice. Thanks for the comparisons.
Old May 11, 2010 | 07:09 PM
rich2342's Avatar
rich2342
Might be adding these soon. I want a dyno graph just like that.
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
Li1ag
Sep 28, 2015 02:07 PM
