headers wrapped...
Old Jun 26, 2009 | 12:35 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Coo! Good luck on dyno!
Old Jun 26, 2009 | 03:45 PM
Originally Posted by gabe3d
What kind of wrap are those, looks interesting? It's true that with uneven wrap that the headers can crack since it'll create hot spots, but it's more of a combination of it with low grade alloy used on the headers. You can see a lot of race cars using heat wrap including the Nismo Fairlady 380RS. The thermal insulation capability of the wrap has been tested to be greater then ceramic coating. I've also wrapped, silicon coated, and silicon sealed my headers.
This is with the Tomei Wrap (much easier to use) and DEI's silicon sprays.
Let us know if you can install these "as is." Just getting to the studs and bolts will be hell.
Old Jun 26, 2009 | 04:07 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Originally Posted by imonlykidden
Looks like it was dunked in some kind of concoction over and over!
Dude. WTF is that icon you have? Is that a drive through Ronald McDonald shoving a gun in Burger Kings face and blasting him?
That's freaky!
Old Jun 26, 2009 | 06:58 PM
gabe3d's Avatar
gabe3d
They are in already just the way they are in the pics. They look a lot beefier in pic because of the spray, but in reality the wrap thickness is only one pass almost everywhere. The Tomei even though are larger and even larger with my wrap, are well design and does not interfere with anything. My older ones were smaller and was touching the steering rod. If you saw the way the unwrapped Tomei Headers are you'll understand why it makes it nearly impossible to wrap and why it looks so big (nearly took 5 hours to come up with a wrapping scheme that worked).
Here is a link to a thread in the NA section with the results, dyno, and soundclip.
https://my350z.com/forum/na-builds/4...m-install.html
Old Jun 27, 2009 | 09:54 AM
Z_HighSpeed's Avatar
Z_HighSpeed
went to dyno @ the r/t tuning meet.
watch the vids, pix show the numbers, average I guess for test pipes/cat back/intake
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/vRlty7tjAPk&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/vRlty7tjAPk&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/CnIRiNhcf70&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/CnIRiNhcf70&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Old Jun 27, 2009 | 12:50 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Nice, time to buy my utec and tune it urself!!!
Old Jun 27, 2009 | 08:26 PM
fabre80's Avatar
fabre80
Is that with headers?
Old Jun 27, 2009 | 08:34 PM
Z_HighSpeed
nope just w/ test pipes cat back and intake
Old Jun 27, 2009 | 08:39 PM
fabre80's Avatar
fabre80
Cool man , i hope with these headers you'll gain some more.
Old Jun 27, 2009 | 08:56 PM
Z_HighSpeed
as do I, if I can hit around 275 tuned I'll be happy.
Old Jun 28, 2009 | 05:03 AM
gabe3d's Avatar
gabe3d
Good results. Looks like you'll definitely benefit from a good tune. Is your baseline 249 plain-o stock?
Old Jun 28, 2009 | 05:05 AM
Z04's Avatar
Z04
hate to see what those headers will look like in a year. good luck OP
Old Jun 28, 2009 | 05:19 AM
Z_HighSpeed
no not stock, test pipes, turbo xs cat back, mishimoto intake
As far as the headers go, I am not too worried...if they break or whatever happens I'll just buy the longtubes...
Old Jun 28, 2009 | 05:44 AM
gabe3d's Avatar
gabe3d
Oh, so this is two runs with the same setup?
Old Jun 28, 2009 | 05:53 AM
Z_HighSpeed
it was actually 3 runs, but the first run is same as second run lol...
yea same setup as stated in my previous comment.
next runs will be with my upgrades...
Old Jun 28, 2009 | 06:02 AM
gabe3d's Avatar
gabe3d
I see, it's surprising to see that your TQ variation from run to run is almost 15TQ diff through alot of the revband. I've never seen that before. Is your dyno SAE corrected?
Any reason why you didn't add a plenum spacer to your car? What year is your car?
Old Jun 28, 2009 | 06:44 AM
Z_HighSpeed
first dyno will be:
Test Pipes
TurboXS 3" straight exhaust (no cats just a muff)
Mishimoto c/f intake
dirty wheels...lol (thats neq hp)
untuned
After install dyno will be:
Test Pipes
Headers
5/16 iso spacer
rota wheels (woot ++ hp lol)
tuned and untuned....hopefully if I can find a shop
my z is an 03 and the dyno is at R/T tuning which are pretty good
Old Jun 28, 2009 | 07:05 AM
  #38
gabe3d's Avatar
gabe3d
I see, forgot about that post
Not that I'm saying their dyno is unreliable but it is good for you to know if it is SAE corrected or not. It usually tells you at the bottom of the dyno where the legend is at for each of the Trends with the run conditions.
If the runs you are doing are no load runs then you may not see any differences when you compare the two graphs for the impact on performance wheels have. Here is a link to a post on g35driver where Hydrazine from Motordyne and myself have done comparing wheel size to dyno results.
http://g35driver.com/forums/tuner-dy...rims-dyno.html
Old Jun 28, 2009 | 07:45 AM
  #39
Z_HighSpeed
I know what your talkin about...I didn't check but I will next time around.
Old Jul 1, 2009 | 06:05 AM
  #40
fabre80's Avatar
fabre80
You will feel the difference in power in the midrange with the Headers. I sure noticed it when they got installed.
