Noise after installing Injen CAI
Old Sep 29, 2003 | 06:25 PM
silver&black03's Avatar
silver&black03
Question Noise after installing Injen CAI
Whats up everyone? I just installed an Injen CAI and now I have this jingling noise under the hood when I drive. It only does it when I am lightly on the gas, If I get on it the noise goes away. The funny thing is, is that I put the stock system back on and the noise is gone. put the Injen back on and the noise returns. It does it in all gears,its driving me crazy. All the clamps are tight. ? Help!
Old Sep 29, 2003 | 08:08 PM
failsafe's Avatar
failsafe
....for your health
there is a small arm that bolts the the metal bumper inside the nose (Its about 4-6 inches above the actual filter) did you attach that little arm to the metal bumper (crash guard)?
Old Sep 29, 2003 | 08:36 PM
SixRB6's Avatar
SixRB6
Default Help!
I have the same noise!!!
And that little arm above the filter is attached. I thought I was hearing things but I read this post and was like HOLY Sh*t Can anyone help us??
Old Sep 29, 2003 | 08:46 PM
failsafe's Avatar
failsafe
....for your health
Bolts on the heat shield possibly loose?
Old Sep 29, 2003 | 08:50 PM
Mr Twisted's Avatar
Mr Twisted
I've got the same thing I thought it was back pressure reverberation in the main tube It's kind of a metalic vibration Mostly get it when I hit bumps at low speed Thought it was a muffler heat sheal but it checks out oK.
A zillion of you guys have had them for a while what is it and how do we fix it...??
Old Sep 29, 2003 | 09:03 PM
failsafe's Avatar
failsafe
....for your health
I never had a metallic vibration on my CAI. sorry, no help.
Old Sep 30, 2003 | 07:14 AM
350_Z's Avatar
350_Z
My heat shied would make a metallic noise, it turned out that it was hitting a line just under it. I bent it up a little and the sound went away. To test it out, take the heat shield off and drive around it the sound is still there then it is coming from another source.
Old Sep 30, 2003 | 07:21 AM
TheBigShow's Avatar
TheBigShow
sorry, guys, i have an aem. i did have a metallic tappin, so i repositioned my maf. took care of it. pop the hood and if u can't here it, give it a little gas. u should b able to hear where it's comin from atleast.
Old Sep 30, 2003 | 07:37 AM
pimp1911's Avatar
pimp1911
Or take a small piece of rubber hose and wrap around line. I am currently having the same minor problem and havent fixed it yet. Will do it tonight.
Old Sep 30, 2003 | 01:09 PM
silver&black03
Everything is tight. All the hose clamps, the bracket under the bumper, the 2 heatshield bolts. I am going nuts now, But check this out.... I was running it as a CAI with the filter in front of the grille, now I changed it to a short ram and the noise is still there only it has a slightly higher tone, but the source of the noise seems to have moved. It is almost as if the noise is from the filter. I am going to remove the filter and drive up my road. I will let you guys know what happens. Peace.
Old Sep 30, 2003 | 02:11 PM
MGV156's Avatar
MGV156
Is it a hissing sound? If so, it's normal. Just a reminder, don't set it up as a short ram. My Service Engine Soon light turned on and off randomly when I had the intake set up this way.
Old Sep 30, 2003 | 02:15 PM
silver&black03
no it is not a hiss. i it is a metallic vibration rattle noise. it does it at low rpm and clears up mid to high rpms
Old Sep 30, 2003 | 02:59 PM
failsafe's Avatar
failsafe
....for your health
I'd go with BigShow's suggestion and try to reposition the MAF- if the harness is facing upwards it may be hitting the hood.
Old Oct 1, 2003 | 12:00 AM
LeighJr's Avatar
LeighJr
is the dipstick hitting the intake?? I just had an oil change and noticed the stick was scuffing the intake tube??
Old Oct 1, 2003 | 08:24 AM
arvin's Avatar
arvin
I have the same jingling sound. I have checked all my clamps and tighten them but it doesn't seem to help. I will try repositioning the maf and see what happens.
Old Oct 1, 2003 | 06:00 PM
SixRB6's Avatar
SixRB6
Default LeighJr might have something!
Dude you might have solved my problem!! I did notice when I checked my oil that #1 the dipstick is unlike anything I have seen! Is it supposed to be that hard to take out??
And I does lay against my Injen tube! I will try to move it and let you know!
Obadabot
Jun 18, 2023 11:31 PM
Z King
Vendor Wanted
13
Oct 22, 2015 11:39 AM
