ok to drive without o2 sensors?
Old Sep 3, 2009 | 11:49 PM
Z-Dub's Avatar
Z-Dub
Question ok to drive without o2 sensors?
i searched and couldn't find anything. couldn't get the sensors out of the stock cats to put in the test pipes, so will it be ok to drive the z without them?
Old Sep 4, 2009 | 02:58 AM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
No.
Old Sep 4, 2009 | 09:37 AM
Z-Dub's Avatar
Z-Dub
Originally Posted by TreeFiddyZee
No.
air/fuel ratio?
Old Sep 4, 2009 | 11:50 PM
Z-Dub's Avatar
Z-Dub
can someone answer why i need them? other than the ses light, i don't know why. i thought the downstream o2 sensors were only to check for emissions...not air/fuel mixture
Old Sep 5, 2009 | 05:31 AM
TreeFiddyZee
Do WHAAAAT!?
It is for emissions, but it does also adjust the A/F ratio.
http://auto.howstuffworks.com/question257.htm
Old Sep 5, 2009 | 05:51 AM
Here you go: http://blog.remartautoparts.com/2009...yting-you.html
Old Sep 5, 2009 | 08:18 AM
j.arnaldo's Avatar
j.arnaldo
Thanks, I benefited from that, too, davidv! My Z has 22,300k on her, so I'm good for now.
Old Sep 5, 2009 | 08:27 AM
Good. American cars doing a cat-delete substitute a oxygen simulator to send a signal to the ECU. I know of no similar component for the 350Z.
BTW this is why I frown on stuffing a non-fouler with steel wool.
Old Sep 5, 2009 | 10:01 PM
Z-Dub's Avatar
Z-Dub
thanks for the replies. i plan on getting new ones or trying to get the old ones out of my stock cats, but if i run without them for a week or so, am i only hurting my gas mileage or am i damaging the z?
Old Sep 6, 2009 | 03:51 AM
DC350ZTrack's Avatar
DC350ZTrack
I've been running without O2 sensors using a custom Osiris Uprev tune for the past 2 months without any issues. Yes, I'll need to replace them before my next emissions inspection in MD - but running without them hasn't caused any issues with the car ('04 Z). The key here is proper ECU management - if you don't have a UTEC, Uprev or something similar, you're going to have problems. Good luck!
- Matt
Old Sep 6, 2009 | 05:32 AM
plumpzz's Avatar
plumpzz
Go to napa and get an O2 sensor socket. it removes O2 sensors using a ratchet. Its cheaper than getting new O2 sensors. Do not spray the sensors with wd40 or oil to make them easiwer to remove
http://matcotools.com/Catalog/toolca...ype=T&cat=2387
Old Sep 6, 2009 | 05:35 AM
abo's Avatar
abo
i've been running test pipes for 2 weeks now without the cat o2 sensors. not really important from what i understand. just an annoying "service engine soon" light. only problem is that i wont know when there really is a problem with my car.
i plan on putting the CEL fix on by tuesday thou.
Old Sep 6, 2009 | 07:04 AM
j.arnaldo's Avatar
j.arnaldo
Yep, davo'; for my bone stock baby, it's only OEM parts---'xept for the oil filter. Some engineer did his homework scientifically, and went ahead and purchased a sample of EVERY oil filter on the market, did "surgery" on each one, and arrived at the conclusion that PUROLATOR'S PUREONE is the one to go with. Sweet, 'cause they're NOT as expensive as OEM ones, and they're BETTER!
Old Sep 6, 2009 | 07:19 AM
Lean and rich is subjective. The potential problem is lean near redline. This is not good. If you must drive keep the RPM below 5,000.
Old Sep 6, 2009 | 01:56 PM
Z-Dub's Avatar
Z-Dub
congratulations on your aftermarket oil filter and your OEM parts on your stock 350Z!!
anyway, thanks for the info people. i'm going to try to get my o2 sensors out of my stock cats without damaging them. are there any penetrating sprays i can use to help loosen them without damaging them?
Old Sep 11, 2009 | 01:52 PM
sportbiketed's Avatar
sportbiketed
Try a torch to heat it up, thats what i had to do to get the sensors out
etkms
Jun 19, 2022 06:30 PM
Dr.Paulyy
Jul 29, 2019 07:45 AM
350z_z33.
Jul 3, 2017 04:01 AM
NissanZcrazy
Nov 2, 2015 06:03 PM
FromGtoZ
Sep 20, 2015 03:41 PM
