why does AAM not send upper gaskets with the test pipes?
Old Sep 22, 2009 | 10:58 AM
Z-Dub's Avatar
Z-Dub
Originally Posted by MDHRZ
Who did you talk to? Name?
i have no idea what his name was. i was driving on the interstate, trying to take advantage of what time i had to call and ask about gaskets, so i couldn't really remember names. he acted as if he uses copper gasket spray for everything in his life...possibly even as a nasal cleaner from the way he talked.
it's no big deal. it's not like my z is going to blow up without them, but the sound of air leaking from my exhaust is starting to get old. i have checked all the pipes and clamps to make sure there is no leak at any spot (it may just be a problem with the combination of the aams and the bassani, but i want to try everything possible before i have to give up this exhaust)
i'm just going to order the berk gaskets.
Old Sep 22, 2009 | 11:00 AM
Z-Dub's Avatar
Z-Dub
Originally Posted by Mamounas123
i used my the stock rings for my Fast intentions test pipes. and have no leaks. you need to tape the ring well on the header so its stays in the same place and just be carefull not to move it as your putting on the test pipe.
i tried that, but one of the rings is a little bent up and worn...plus, they don't work well with the aams
Old Sep 22, 2009 | 11:15 AM
Andrei's Avatar
Andrei
Do your test pipes have those J tubes welded on them? Can you tell me the size of those tubes where the o2 sensors go? Are they 0.75" or 1"?
This is the J tube here.
Old Sep 22, 2009 | 12:12 PM
Z-Dub's Avatar
Z-Dub
yes, they have that.
i can't get under my z at the moment, but the next time i do, i can measure them
Old Sep 22, 2009 | 12:56 PM
Jon@Altered's Avatar
Jon@Altered
PM Sent mang! Sorry about the mix-up.
-Jon
Old Sep 22, 2009 | 09:58 PM
Z-Dub's Avatar
Z-Dub
-Jon
thanks man. i'm going to give the installation another shot. sorry for my misunderstanding
Old Sep 23, 2009 | 10:20 AM
Andrei's Avatar
Andrei
Hey I just found out that they are 1". I appreciate it though.
Old Sep 23, 2009 | 10:36 AM
Jay'Z's Avatar
Jay'Z
What was the end result? Wrong part or forgotten gasket in package?
Old Sep 23, 2009 | 05:35 PM
Z-Dub's Avatar
Z-Dub
neither...i'm just going to have to get more rtv sealer and try again while letting it set on there longer
Old Sep 23, 2009 | 05:36 PM
Jay'Z's Avatar
Jay'Z
neither...i'm just going to have to get more rtv sealer and try again while letting it set on there longer.
Sux.... How long does it take you to pull??
Old Sep 23, 2009 | 06:02 PM
Z-Dub's Avatar
Z-Dub
what do you mean?
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
