Kinetix test pipes making a wierd sound??
Old Oct 30, 2009 | 06:00 AM
033fftz's Avatar
033fftz
Default Kinetix test pipes making a wierd sound??
i have the kinetix test pipes on my car and the stock exhaust and it makes a wierd hiss noise any ideas? also if i were to put the stock cats on with a cold air intake and plenum spacer would that be a problem like to much air? and not enough going out
Old Oct 30, 2009 | 07:11 AM
R350Zz33's Avatar
R350Zz33
the hiss is because u have grater airflow listen to my turbo xs test pipes i have a cold start vid a warmed up one and a drive around.
cold start:
http://www.youtube.com/watch?v=zv04740iM5M
warmed up:
http://www.youtube.com/watch?v=RvdmY...eature=related
drive around:
http://www.youtube.com/watch?v=6-Qux...eature=related
the drive around you can hear it the best they ARE broken in when i took this video
Old Oct 30, 2009 | 07:54 AM
gabez33's Avatar
gabez33
hiss with TP is normal, so is usually rasp, and a metal slappy type sound.
Old Oct 30, 2009 | 08:15 AM
diablox1's Avatar
diablox1
perfectly normal. just tell people you installed a couple of snakes under your car and they likes to hiss once in a while.
Old Oct 30, 2009 | 09:53 AM
Probably need new gaskets.
Old Oct 30, 2009 | 11:38 AM
033fftz's Avatar
033fftz
thanks alot guys also if i put my stock cats back on with the plenum spacer and cold air is that gonna be a problem?
Justin100
Nov 29, 2015 03:58 PM
codek
Sep 28, 2015 03:03 AM
z33z_nutz
Sep 23, 2015 07:22 PM
_koubie_
Sep 20, 2015 06:34 PM
