so I just ordered V2 megan test pipes w flex.. are the gaskets safe to use?
Old Dec 12, 2009 | 09:44 PM
sammyG350gt's Avatar
sammyG350gt
Default so I just ordered V2 megan test pipes w flex.. are the gaskets safe to use?
title says it all.. I just ordered a set of megan racing version 2 test pipes (upgraded version with flex joint) and I'm wondering if the supplied gaskets are safe to use. I know this is a relatively inexpensive product and would like to avoid any possible problems.
Has anyone had an issue with these gaskets? Did you use higher quality ones? berk.. etc... ?
thank you
Old Dec 12, 2009 | 09:50 PM
AUS10TAT10US's Avatar
AUS10TAT10US
Why wouldn't they be safe? I have these test pipes too and the gaskets that came with them are actual pretty quality gaskets if you ask me. You will be fine.
Old Dec 12, 2009 | 10:35 PM
s31t8n8's Avatar
s31t8n8
I doubt they will last long considering theyre from Megan. If possible, reuse the stock metal ones because they are way better than the crappy gaskets you get with all cheap parts
Old Dec 12, 2009 | 10:46 PM
Z You Later's Avatar
Z You Later
just letting you know that you need to be aware that they may not last you long...i had the same ones and one side ate the cat within 2-3 months...the saying you get what you pay for actually plays apart...just hope you get longer life out of yours
Old Dec 12, 2009 | 11:38 PM
Old Dec 13, 2009 | 06:48 AM
albaugh81's Avatar
albaugh81
I didn't get any gaskets with my berk.
Old Dec 13, 2009 | 07:12 AM
t6378tp1's Avatar
t6378tp1
I reused the oem gaskets
Old Dec 14, 2009 | 04:43 AM
Gingervitis526's Avatar
Gingervitis526
I got some cheap gaskets with my test pipes and had to replace them with the OEM ones.
Old Dec 14, 2009 | 08:43 AM
Z You Later
most people don't realize that the OEM seal better and last longer...but diameter holds back many with 3" tubing
burglapfd
Dec 6, 2020 01:04 PM
TrboMike
North East
Sep 28, 2015 06:36 PM
Tylerx7z33
Sep 21, 2015 01:43 PM
Nicky R
Sep 20, 2015 01:05 PM
