Nismo headers...install question?
Old Oct 20, 2003 | 10:41 AM
greddy4777's Avatar
greddy4777
Default Nismo headers...install question?
what sup folks? hope everyone had a great wkend...
i had my nismo headers installed this wkend. they sound great and can def feel the highend power BUT i guess the steering baring is just resting on one of the tubes...where the weld is...its just touching it....
result...vibration in the steering column when driving and after 3500rpm.....
those with the Nismo headers...have you encountered this slight problem...and if so how did you solve the problem...?!?
should i shave a lil off the weld...?
worse come to worse i can always have them send me another one...
thanks
eric
Old Oct 20, 2003 | 11:04 AM
PhoenixINX's Avatar
PhoenixINX
Several owners have mentioned this...
Looks like whomever did the NISMO headers didn't do a good enough job to make sure they didn't rub.
Headers take a LOT of time to R&D.
Old Oct 20, 2003 | 11:28 AM
greddy4777's Avatar
greddy4777
i did a serach and didn't find this. all i found what that it was a pain in the **** to put those suckers in.
i thought that i read all of the nismo threads....guess not...do you remember where you found these threads....?
thanks
Old Oct 20, 2003 | 01:02 PM
VandyZ's Avatar
VandyZ
We saw this with the set installed on mjedens car. The nismo headers are still assembled by hand (I think) so errors are possible. You may want to see if you can adjust the steering linkage knuckle up or down a bit to clear. But that will only work if it is only off by a hair.
Old Oct 20, 2003 | 01:35 PM
greddy4777's Avatar
greddy4777
VandyZ...thanks buddy for your input...the mechnics at nissan mentioned that..and we are going to try to do that..or we just might heat the sucker up and put a lil dent in it...haha
but thanks for ur reply...just a FYI...i'll be a customer of yours soon with the plenum...
Old Oct 20, 2003 | 04:34 PM
Jeff@Performance's Avatar
Jeff@Performance
Performance Nissan
Mine also rub against the steering rod on hard right corners. We just gave them a little whack and it went away. You would think for as much as they cost the quality control would be a bit better.
Old Oct 20, 2003 | 05:24 PM
greddy4777's Avatar
greddy4777
ya think..thanks Jeff...will let them know...i have to say those headers do work tho....luv the sound too
Old Oct 21, 2003 | 04:47 AM
Jeff@Performance
Performance Nissan
Do you have high flow cat's or test pipes? If not that's next and your butt dyno will love it!!!
Old Oct 21, 2003 | 05:10 AM
greddy4777's Avatar
greddy4777
got the test pipes...all i am waiting for is my exhaust...damn UPS....4 crates were ordered but only 3 came in....the other is in LIMBO....someone obviously took it......
Old Oct 21, 2003 | 02:17 PM
alex30327's Avatar
alex30327
Mine vibrate as well, but only under extreme cornering (greater than 0.6 lateral g's).
Whats the best way to fix this? CAn you just whack it with a hammer, or do you need to take it to a welder?
Old Oct 21, 2003 | 02:35 PM
Jeff@Performance
Performance Nissan
I had to loosen the steering coupler, move the steering shaft a bit and gave it a whack with a small hammer. It is so close it really takes very little.
Old Oct 21, 2003 | 05:16 PM
Nano's Avatar
Nano
Do other headers have this problem too? Or just the Nismo?
Old Oct 21, 2003 | 06:16 PM
alex30327's Avatar
alex30327
I'm going to try this next time I take my cats off. My vibrations aren't bad, just noticable when I pushing the car to its limits. This fix should be quite easy to do.
Thanks
Old Oct 21, 2003 | 07:12 PM
greddy4777's Avatar
greddy4777
i will have to try this too...my guy tried to heat it up but it was to tight to get a hammer in there....
will try ur way tho
issyz
Jul 2, 2017 03:04 PM
nanotech
Oct 2, 2015 05:02 AM
