Install time/money spacer
u also need some sockets (dont remember now what size but prolly 10mm)and a ratchet but u will need that at the end to torque the plenum back down after u put the spacer in...just some basic tools, thats really the only specialty tool u will need
14 mm deep socket, 10mm socket, micro-torque wrench or nut driver, crescent wrench, and plyers and a screw driver (to pull off vaccum lines). I also used a piece of string and tied the upper plenum up to the hood while I put the spacer in place.
A slightly mechanically-inclined person can install one within a few hours.
A person that knows what he's doing mechanically and has had the VQ plenum off previously will be able to do it in an hour or less.
I did the iso thermal and that is the write-up that I did in the DIY section. It may be overly detailed, but I wrote it up for idiots like myself to follow.
lol @ 4 hours....
I switched out my upper plenum lower plenum and intake runners at a dyno day. this includes removing injectors and rails. I only had the tools I brought with me, I did this out in a parking lot.
Took me a little over 1 hour. I am not a mechanic, only mechanically inclined.
haha, good quote.
I did mine in an hour maybe less. being a mechanic helps but it was a very basic install.. easy enough for a 12 year old I would say
dont get fooled by shops. do your own work and it will keep a hole from burning in your pocket
I am in the same boat... But I am planning on using the money I would spend to to have someone else install it and invest in the micro torque wrench and just doing it myself... I also plan to go ahead and change my spark plugs while I have easier access during the install
Dave
