test pipes or headers??
Old Mar 8, 2010 | 12:01 AM
armintheman's Avatar
armintheman
thanks guys all the comments have been helpfull. now as for resonated test pipes vs hfc. which would give me more power and which would be more raspy? my guess i'll make more power from the test pipe but it'll be more raspy. correct?
Old Mar 8, 2010 | 05:01 AM
SoarVigor's Avatar
SoarVigor
Yes. Get Motordyne Xy Pipe with the HKS
Old Mar 8, 2010 | 05:24 AM
Ronin82's Avatar
Ronin82
Originally Posted by binder
unless you're doing a heavy built NA or going to FI then headers are a waste. Cost per benefit are way down the hole. Say 800$ for headers and at least 500$ (more like 1000$) for a shop to install it.
also, headers really won't change your exhaust note. Test pipes will. Test pipes are simple to install, not expensive so they are good bang for buck.
I would do test pipes and spend the extra money on a dynotune. With both of those you'll still be well below the total cost to have headers put on.
Headers did change my exhaust note,.. not drastically but there was a level up in agressiveness note. but I had TDE and HFC on it prior to that install.
without a tune you will probably lose power. headers that will show decent gains NA are going to cost a lot because it takes a lot of R&D to design a perfect flowing header.
Definatley right on this one, heavy builds that go into cam work possibly with porting, and Definatley right on a reflash. Will lose power without the reflash minimum.
Test pipes are great.... but I just don't think(opinion) its practical for every day street use, maybe really not nessesary, personal fan of HFC's though.
But if your planning on tracking, then hell yeah.... test pipes for sure!!
Old Mar 8, 2010 | 06:12 AM
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
Why no do both
Old Mar 8, 2010 | 06:49 AM
Ronin82's Avatar
Ronin82
Originally Posted by Chris@FsP
Why no do both
He could do both, but there wont be a gain with the Exhaust manifolds. realistically and from experience its gonna feel like low end torque drops a lil, even with upgraded Cats.
Ive asked the question before on header dimensions to try to see what kinda headers are most compatible without having to do heavy builds and no one really knows.
Old Mar 8, 2010 | 07:02 AM
binder's Avatar
binder
i completely agree but for the amount it changes it it wasn't worth noting, at least in my case. I'm sure it's probably brand dependant on how much it changes the volume and tone of the exhaust. For my headers through a borla true dual if there was a difference it was so slight that i haven't noticed it.
HFC or test pipe question. If your state doesn't test emissions then test pipes will get you the "most" gains. Resonated test pipes will help reduce the rasp but rasp is also a factor that will depend on your exhaust as well.
HFC are great, depending brand they'll flow slightly less than test pipes. Flow won't make that must difference in an NA application. I chose not to do HFC due to their failure rate and being an FI car i wanted the most flow i could get. A quality HFC will last but there is always an element of possible failure of th catalytic which will clog the exhaust. The risk is minimal but it will be your decision whether it is worth it or not.
Old Mar 8, 2010 | 07:50 AM
Chris@FsP's Avatar
Chris@FsP
Low end torque is great for driving around town, but I'd rather give some up down low and make it scream up top If you are racing under 4krpms, you're doing it wrong
Old Mar 8, 2010 | 08:19 AM
armintheman
hahaha i like that "if your racing under 4krpm your doing it wrong". ok so basicly headers are out of the question now if a matter of high flow cats or resonated test pipes.
binder- i completly agree for the hfc failier rate i've heard alot about that. plus they're about twice the price.
i think im between the motordyne art pipe (which are really pricy and i think it's still a little raspy), or just any brand test pipe that has resonators on it. does anyone have resonated testpipes on a hks tde?
Old Mar 8, 2010 | 08:21 AM
Chris@FsP's Avatar
Chris@FsP
The ART pipes that I've installed actually removed the rasp previously caused by a set of HFC's.
Old Mar 8, 2010 | 10:33 AM
armintheman
really?! do you have a you tube video of them on your car? i wanted to hear it
Old Mar 8, 2010 | 10:35 AM
Ronin82's Avatar
Ronin82
Under 4K... thats funny.
I wonder what the failure rate is among HFC brands are.
I've had AAM's in just over a year in my daily driver and I shift typically over 4K RPMs.
Old Mar 8, 2010 | 06:22 PM
wolfman13's Avatar
wolfman13
Originally Posted by tylerxfire
^^wolfman above .my berk high flow carts cracked right at the mounting brackets on both sides, so i wouldnt be caught up on ones that have mounting brackets..test pipes dont weigh very much so they dont need them for the most part
I installed megan racing test pipes which do not have mounting brackets. After being under my car while a friend reved on it, i found that they were moving a little more than i felt comfortable with. Not to mention my y pipe was leaking. (Due to too much movement i'm guessing) So i had a local muffler shop rig me up a few mounts.
Old Mar 22, 2010 | 11:47 PM
Caledan's Avatar
Caledan
Thank you, this info was extremely helpful to me as I was wondering about installing HFC~ I didn't want to go w/ test-pipes mainly due to the noise/emission/legal issues~
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
