Berk HFC Question !
Old Apr 14, 2010 | 04:33 PM
350ZGTS's Avatar
350ZGTS
Question Berk HFC Question !
whats the difference between the Berk HFC and the Berk HFC W/ Spiral Wound Technology ?
and will they pass smog ???
thanks !
Old Apr 14, 2010 | 05:38 PM
Not sure but Spiral Wound Technology sounds cool. This is some sort of technique to eliminate cracking? Instead of giving us incomprehensible jargon, how about a 36 month warranty against crackling?
Do not know about smog requirements in your state.
Old Apr 14, 2010 | 05:45 PM
User 42426's Avatar
User 42426
where did u hear about spiral wound technology?
Old Apr 14, 2010 | 05:47 PM
calin's Avatar
calin
I'm not sure what the difference is, but no HFC's will pass smog.
Old Apr 14, 2010 | 05:55 PM
cdoxp800's Avatar
cdoxp800
thanks !
That all depends. There are people out there running them and Passing the Smog test.
The Spiral Wound Technology is just the way the Cat is made. It has nothing to do with Passing smog test. It helps create a HFC.
http://www.berktechnology.com/shop/p...D=106&P_ID=433
Old Apr 14, 2010 | 08:49 PM
350z006's Avatar
350z006
Originally Posted by cdoxp800
That all depends.
+1, some states are more lenient than other...
but OP since you're in Socal, you will not pass...California has the strictest, **** tests for smog...you will probably fail visual (since they require OEM cats in this state) and even if you get past that the metallic cats just don't perform enough to pass California smog...
Old Apr 14, 2010 | 09:22 PM
350ZGTS's Avatar
350ZGTS
yeah i think with my set up on my car i wouldnt pass smog
but i seen other HFC that say it will pass smog
Old Apr 14, 2010 | 09:35 PM
derek173's Avatar
derek173
I might have some for sale soon, PM if you are interested.
Old Apr 14, 2010 | 09:55 PM
350z006's Avatar
350z006
Since different states have different rules for smog, its technically true that certain HFC's will pass smog...in more lenient states...
Now if the HFC's says it will pass in California, then let me know because I want it...
Also, when you check out the websites for most HFC's they will say they are for off road use only, or maybe at best 49 state compliant; guess which is the 50th state it isn't compliant with?
Old Apr 15, 2010 | 06:25 AM
350ZGTS's Avatar
350ZGTS
well with Berk HFC's they say 49 states, so idk if we are in it
but with a ecu reflash will it pass smog ?
Old Apr 15, 2010 | 07:57 PM
350z006's Avatar
350z006
I can promise you that California is the 50th state that the Berk is non-compliant with...
As for tuning your car so you can pass smog, I suppose you can try tuning you car lean (I actually briefly thought about it for my setup) but do you really want to drive a car tuned lean? Risky for the engine...
Old Apr 18, 2010 | 06:26 PM
350ZGTS's Avatar
350ZGTS
naw its not worth it !
ima just save up for some new wheels
Old Apr 23, 2010 | 02:41 AM
NissanGeneration's Avatar
NissanGeneration
Vendor - Former Vendor
no HFC will pass smog in California.
My intercooler piping was chrome the smog guy told me to go home and will not pass me.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
