Skunk2 plenum spacer
Old Apr 21, 2010 | 03:59 PM
BristishZ's Avatar
BristishZ
Default Skunk2 plenum spacer
Hey guys, I just ordered a skunk2 racing plenum spacer through my work and was reading up on it a little more and it says that it doesn't work with the factory strut bar. I was wondering whether this is just them being over concerned and just saying that. Has any one had any experiance with this plenum spacer? Thanks guys
Old Apr 21, 2010 | 06:04 PM
Depending on the thickness it may or may not work.
Old Apr 21, 2010 | 06:17 PM
dbrown's Avatar
dbrown
like davidv said i think the biggest you can get is 5/8 if you ordered a 1/2 it def. will not fit..
Old Apr 21, 2010 | 06:36 PM
eltness350's Avatar
eltness350
The Untouchable
i have the thicker of the two...5/8 i believe and yea no oem strut bar...i got a aps one now...there are others also that will work but u can drive without a strut bar...just wont handle quite as well...
Old Apr 21, 2010 | 07:03 PM
BristishZ's Avatar
BristishZ
well there was only one thickness to order from. Do you have a strut bar on there now with your skunk2 spacer. i wanted to keep the factory strut bar. and to those who have used them, do you feel a pretty good gain from it? thanks
guys
Old Apr 21, 2010 | 07:06 PM
Entaille's Avatar
Entaille
should have researched it prior to purchasing. you may be able to use spacers on your strut tower bar to lift it a little without hitting your hood. you'll have to play around.
Old Apr 25, 2010 | 04:13 PM
killerbee's Avatar
killerbee
i have the 5/8 plenum on my 03 and yes you do have to remove oem strut bar. I am now using a crawford strutbar.
Old Apr 26, 2010 | 08:31 PM
C-Dub's Avatar
C-Dub
I also have purchased a Skunk2 spacer without enough investigation. The Crawford strutbar will clear the Skunk2 spacer and the hood?
Old Apr 27, 2010 | 06:04 AM
Ruthless18x's Avatar
Ruthless18x
Skunk spacers are notorious for leaking. I'd say the strut bar is the least of your worries.
Old Apr 27, 2010 | 08:28 AM
killerbee's Avatar
killerbee
Yes it will, here are some pics that show the strutbar. Note that the sk2 spacer are not in these pics but you get the idea:
Ruthless18X:Skunk spacers are notorious for leaking. I'd say the strut bar is the least of your worries.
BTW: These are not my pics, just some i found.
I must admit that the 1st ones that came out did, but i have a 2nd gen one (one with the sealant already there). I just check it every now and then to be on the safe side.
Old Apr 27, 2010 | 11:58 AM
BristishZ's Avatar
BristishZ
yer, its the second version i bought, got it through my work at a good price. its 5/8 and has the new rubber sealant all the way around. So planning on getting that installed this weekend. i have pictures of it and the rest of the stuff i have done, just havent put them up yet, i will put them up this weekend and see how it goes, thanks for the feedback guys
Old Apr 27, 2010 | 08:45 PM
C-Dub's Avatar
C-Dub
Thanks, Killerbee. Is Crawford the only one that you know of?
Old Apr 28, 2010 | 10:30 AM
killerbee's Avatar
killerbee
Your welcome. The Stillen bar and also the APS are in front of plenum design as well and will work.
allmycarsdie
May 13, 2016 04:38 PM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
