Which gaskets for Test pipes?
Old May 14, 2010 | 06:20 PM
G4nismo's Avatar
G4nismo
Default Which gaskets for Test pipes?
I just bought some 2.5'' strup TPs but I'm going to have to buy all the hardware and gaskets. The stock diameter is 2.25 but w/ the TPs being 2.5, I'm thinking I should go w/ a 2.5 diameter gaskets or does it matter?
I been searching around places to buy gaskets other than nissan (will use as last resort) and was wondering if these gaskets for the header to cat were ok:
http://cgi.ebay.com/ebaymotors/Exhau...#ht_3174wt_902
my concern w/ these would be the clearance as they are as stated about 2mm thick uncompressed where as the stock looks really thin and flimsy. Should I be ok with these?
anyone know any other places for the cat to y-pipe gaskets?
Old May 14, 2010 | 08:48 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Between the stock headers and your test pipes, use the stock gasket. The stock header exhaust gaskets are good, reliable and reusable.
For the outlet of your test pipes, you will have to use the same diameter gasket to match up with your catback.... what ever diameter that may be.
Old May 15, 2010 | 04:01 AM
Gingervitis526's Avatar
Gingervitis526
+1 on using the stock gasket between the header and test pipe. I used the one's that came with my pipes and ended up having to replace them in less than a week.
Old May 15, 2010 | 04:34 AM
FATPUBUS's Avatar
FATPUBUS
Vibrantperformance.com
Old May 15, 2010 | 06:37 AM
G4nismo's Avatar
G4nismo
awesome, thanks! The car has about 24k miles on it, do you guys think I would be able to reuse the head to cat gaskets or just go ahead and buy new ones? I guess I would also have to visually inspect them for myself and make the final decision.
Old May 15, 2010 | 07:00 AM
Gingervitis526
I reused mine and I have 60k on them. If youre worried about it you could always use some liquid gasket type stuff in addition to the OEM gaskets.
Old May 15, 2010 | 07:44 AM
G4nismo's Avatar
G4nismo
mmm ok, i'll prob just do that instead. Just called nissan and they quoted me $16.35 each for those gaskets which is ridiculous.
sales@czp
Sep 23, 2019 03:30 PM
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
