So What's Up With This Tomei Ti Exhaust?...
Old Mar 18, 2013 | 05:03 PM
  #81
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Old Mar 19, 2013 | 01:02 AM
  #82
Kwame's Avatar
Kwame
Lmao.
Good stuff
Old Mar 24, 2013 | 12:10 PM
  #83
TimsZee's Avatar
TimsZee
Soo! Got the exhaust on today and boy what a day. Sounds great and went together easy enough. So that silencer that comes with it.. It's a TRAP! Put it in for laughs and turns out the exhaust got the last laugh. Got stuck and had to take off the muffler. But here's some pics and some before and after videos!
Old Nismo ( I loved this exhaust so much.. )
http://www.youtube.com/watch?v=xMod6...ature=youtu.be
http://www.youtube.com/watch?v=jxpCq...ature=youtu.be
And the new Tomei Ti Single 3"
http://www.youtube.com/watch?v=H_jVJ...ature=youtu.be
Old Mar 24, 2013 | 04:52 PM
  #84
2004Black350z
Exhaust Whore
Well sounds like......ummm.... EVERY Other single exhaust i've owned. Lightweight factor is still cooler
Old Mar 24, 2013 | 05:33 PM
  #85
TimsZee's Avatar
TimsZee
It does sound like every other single, but that weight factor for a few hundred $$ more is well worth it!
Old Mar 24, 2013 | 07:28 PM
  #86
freddys 350z's Avatar
freddys 350z
looks like it hangs alot lower then the AP.
Old Mar 25, 2013 | 08:47 AM
  #87
TimsZee's Avatar
TimsZee
Then again AP has that little indent in the exhaust as well. Maybe that helps it appear to look a little more tucked in there.
Old Mar 25, 2013 | 09:26 AM
  #88
Junkster's Avatar
Junkster
Take some side shots of what it looks like under the car
Old Apr 15, 2013 | 09:05 AM
  #89
idrive_MD's Avatar
idrive_MD
drone levels at highway cruise speeds?
Old Apr 15, 2013 | 05:22 PM
  #90
Nacho Z's Avatar
Nacho Z
You guys mind posting some prices or did you get hooked up? By the way for some reason Kwame's still looks bigger.
Old Apr 15, 2013 | 05:36 PM
  #91
2004Black350z
Exhaust Whore
around 1600$ with y pipe i think
Old Apr 15, 2013 | 08:05 PM
  #92
freddys 350z
i ment the area right behind the muffler. the AP is tucked close to the diff for max clearance.
Old Apr 16, 2013 | 05:22 AM
  #93
TimsZee's Avatar
TimsZee
I'll take some pics today. Drone isn't bad about the same as my Nismo to be honest. The only thing that bothers me is at about 2500 RPMs the springs that are used to connect pieces vibrates for about 200-300 RPMs and goes away.
Old Apr 16, 2013 | 09:05 AM
  #94
Junkster's Avatar
Junkster
^hmm wonder if you could wrap some exhaust wrap in those areas to prevent it?
Just a thought
Old Apr 16, 2013 | 09:24 AM
  #95
Chebosto's Avatar
Chebosto
did you try to turn the springs around, or twist 1/2 turn so that there is more tension?
i thought about plasti-dip the springs so that they would be coated to prevent rattling...
Old Apr 16, 2013 | 09:31 AM
  #96
Junkster's Avatar
Junkster
^plasti dip may be a good idea but i would imagine that burning off once it got hot though....
Old Apr 16, 2013 | 10:16 AM
  #97
boots33's Avatar
boots33
how hot can heat shrink tubing get? it seems like it would be a good fit over the springs
Old Apr 17, 2013 | 05:37 AM
  #98
TimsZee's Avatar
TimsZee
I haven't really messed with it at all to be honest.. Guess it's really not that annoying, just something on the to-do list.
Old Sep 11, 2014 | 02:58 PM
  #99
kenjaaak's Avatar
kenjaaak
I just bent the spring hooks more to 90° angle, which alone created enough space between springs and tubing to stop rattle. I have another question. Have you guys had problem with leaks under the clamp bands? I had to exchange exhaust due to regular technical inspection and 4fun tried to use vacuum to find some leaks on Tomei and end up shocked how horribly leaky it was there. I used some rtv to fix it and now I have to wait to see if it can stand the heat...
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
Li1ag
Sep 28, 2015 02:07 PM
