Invidia G200 help!
Old Aug 30, 2010 | 07:55 PM
Padman's Avatar
Padman
Default Invidia G200 help!
Hi i just got an invidia g200 used for very cheap, the only problem is that it didnt come with bolts or gaskets. I was going to use the stock parts but i do not have enough of either part. I need to know if the gasket size on the Invidia will be the same as the stock gasket size ao i can pick those up and start the install. so if anyone knows this information please help me. As far as bolts, i picked up new ones (12mm) which is what i was told would be the right size. Thanks for the help and sorry for being a "noob."
Old Aug 30, 2010 | 08:18 PM
Shawz1102's Avatar
Shawz1102
I believe the bolts are M6 bolts.
As for the gaskets, stock gaskets should work, so just get the same shaped gaskets. Bring one of your Invidia pipes to local Autozone/Pepboys and find the correct gasket.
Old Aug 30, 2010 | 08:28 PM
Padman's Avatar
Padman
6M? as in 6mm? really i thought 12 but thank you. and i cant believe i was stupid enough to not think to take a pipe to the shop.
Old Aug 31, 2010 | 10:23 PM
Padman's Avatar
Padman
fianlly put it on tonight, everything is perfect, sounds great, looks great.
this thread can be deleted now that i have it done.
Tylerx7z33
Sep 21, 2015 01:43 PM
Obeorangekenobi
Sep 11, 2015 07:17 AM
LOU
Dec 3, 2004 09:04 AM
UltraRev
Oct 8, 2004 07:11 AM
