Help with Finding a Part
Old Sep 19, 2010 | 10:36 AM
Clean Z's Avatar
Clean Z
Default Help with Finding a Part
What is the part between the intake and Plenum?? Where can I buy one?
One of the allen bolts is completely stript and I cant seperate this peice from the stock plenum.
Old Sep 19, 2010 | 11:06 AM
winchman's Avatar
winchman
It depends on what you mean by "intake". I'm going to assume you mean the manifold, which is below the plenum..
http://www.courtesyparts.com/350z-pa...5_716_727.html
If you can get to the head of the bolt, drill it out so the head separates from the grip (the unthreaded part). You can then take the plenum off, and use vice grips or a stud removal tool to get the rest of the bolt out.
Old Sep 19, 2010 | 11:18 AM
winchman's Avatar
winchman
The other possibility would be the throttle chamber.
http://www.courtesyparts.com/350z-pa...5_729_730.html
Old Sep 19, 2010 | 05:35 PM
Clean Z's Avatar
Clean Z
thanks winch, after about an hour of determination I got the bolt out and finished my plenum install
Thanks again tho.
crappycellpics
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
