Nismo Cams Installed
Old Nov 10, 2010 | 08:40 AM
SexyRob's Avatar
SexyRob
Default Nismo Cams Installed
Wow it was a long last four days. just finished up correcting all my mistakes. honestly can't believe T3k_V35 didn't just tell me to fck off after all we went through to get these things in. Major props to Jeremiah for sticking through it with me, his wealth of knowlage and experience made this go smoothly. He was there to smooth over all my fck ups...
Let me give you a timelog:
-Friday: 7:30 pm - 11:30 pm
T3K_V35 (jeremiha) came over.
jack up car, remove wheels, wheel wells, bumper, intake box, z-tube, intake plenum, coil packs, valve covers, vtc solenoids, ac compressor, starter, power steering, grounding connections Idler pulley and belts/tensioners. drain oil and coolant. remove coolant tubes, thermostat and radiator shroud. removed lower oil pan and the two bolts that go to the timing cover. break seal on timing cover and called it a night. also had pizza somewhere in between.
-Saturday: 10:00 am - 6:00 pm
clean off all parts from powdercoater and sand mating surfaces smooth, wash and prepare everything. remove timing components from engine, remove cam sprockets, remove rear timing cover after draining the rest of the coolant.
prepared new cams, cleaned off all surfaces with acetone, cleaned out all oil passages. applied redline engine prep lube on all cam lobes/journals to protect them before oil starts flowing. removed all stock cams and replaced them with the nismo cams appropriately.
cleaned off mating surface of block and heads with a razor and acetone. applied 3m superblack rtv to mating surface of the rear timing cover and spread it out. put rear timing cover back on and torqued all bolts to spec.
jacked around with tightening the cams to spec then trying to figure out the timing sprockets (this was annoying when you don't have experience doing it)
I thought I had it right so I sealed up the valve covers all confident in myself.
then I read the service manual again and noticed there are marks to indicate each timing mark and I had mixed them up, so the cams were off. I had to undo that and rebolt everything down properly. after getting frustrated I called it a night.
-Sunday: 11:30 am - 6:30 pm
Jeremiah came over (thank god) and sorted out my timing mess. he explained that the right and left banks were not from facing the car but opposite. so that helped. got everything slapped back together, gooped up the surface of the timing cover and put it on, everything went smoothly. got all the accessories on and it all looked good. then we filled her up with oil and coolant and turned it on.
immediately I noticed the awesome sound... then I realized it was idling weird which scared me. there was a vacuum hose that I forgot so Jeremiah plugged that quick. after the smoke cleared from burning off the headers I saw it threw a code. before I could check it we realized the temp was getting high from bubbles in the system. I killed the car and we tried to bleed it, although the crappy bleed valve is made from plastic and I stripped that out good when I did my header install. Jeremiah did all he could to try to get the bubbles out other ways, but it wasn't working... this bubble was big. he kept working on that while I checked the code with Cipher. the code was pretty bad, it seems I had skipped a tooth on the timing chain for the bank 2 cam set (the only part I did when he did the timing.)
The car ran, and idled funny, it wanted to die a lot on decel but I was still happy my engine wasn't dead or dying. but I didn't look forward to having to remove the timing cover to correct it. I had to be at a dinner so we just left it as is and I babied the car (keeping under 4k rpms) while I drove there. do you know how hard it is to not floor your awesome sounding cammed VQ??
anyways I drove it as little as possible so to not damage anything and I waited another day to finish the install. one little link on a timing chain was holding me back from the joy I needed to experience. one little link was going to cause another day full of issues.
-Monday 6:30pm - 3:00 am
Jeremiah gets to my place early to try to knock this out. I left my bumper and undercover off so we didn't waste anytime. jacked it up and got after it. removing parts and draining the oil (I filtered it so I could reuse it.)
we got everything off in record time, got the timing cover off and the valve covers and everything we needed to correct the mistake. we didn't have to drain the coolant this time which was good, the bubble had worked it self to the top so even the top radiator hose didn't leak when we had to remove it to get the radiator fan shroud out.
after removing everything we reset the timing, I cleaned off the mating surfaces again and Jeremiah did the technical stuff. I didn't touch it this time but I did watch the magic take place. he was good, he has all these little tips and tricks that helped save a bunch of time. I won't go in to some of his secrets but just know you are in good hands with him.
I rushed to get everything back together and we had the timing cover on and half of the accessories plus the oil pan on before he realized we didn't torque the timing sprockets on to the cams. at this point, I was ready to say fck it and just leave it as it was. he wouldn't let me, thank god!! it took another 45 minutes, but in record time we got the cover off and torqued everything down, the rtv goop was still wet so we didn't have to redo that. everything was good, or so I thought.
I proceeded to rush the process of putting the valve covers on, because I wanted to drive my newly cammed car. In rushing this I jacked up the sealing gaskets on the valve covers and when we got the car all back together it started spewing oil on my headers which made a ton of smoke. so we once again tore down the intake and plenum and vtc solenoids to see what happened. I guess when I put the driver side in the gasket slipped out and I cut it in half when I torqued down on the bolts. the passenger side however, we couldn't figure out why there was oil coming out. either way I was damn lucky to have an extra set of gaskets from a set I acquired awhile back. we threw everything back together for the last time, and added some extra water to the coolant and FINALLY, FINALLY we we done.
it heated up, no codes, no spikes in temp, everything sounded awesome.
I took it for a drive and it was great. not a huge power gain yet but once the ECU adapts it will be sick. the sound is amazing too. I will post before and after sound clips soon.
After driving it around for a day now, feels like I lost some below 3250 rpm, mid range is the same, and after 5k it just screams. I love it!
Other mods
Stock Airbox with K&N Drop in
5/8 Spacer
Ported and Polished plenum, down to the heads
Nismo R-Tune Cams
Strup Coated Headers
AAM Highflow Cats
Bassani True Dual Exhaust
=== Sound files ===
the Mic was 5 feet away from the car, probably should have been a bit further, esp after cams.
beforecams.wma - 605kb
aftercams.wma - 649kb
Pics!
small mess
front cover off
T3K and the front cover
one cam in!
rear timing cover off
medium mess
rear timing cover clean
cams in, timing components on
powdercoated bolts and hard coolant lines
front cover clean
front cover sealed up *the first time*, kinda dirty
Old Nov 10, 2010 | 08:57 AM
Z_HighSpeed's Avatar
Z_HighSpeed
sweettt
Old Nov 10, 2010 | 09:03 AM
TheFarmer's Avatar
TheFarmer
Nice.
Old Nov 10, 2010 | 09:11 AM
kacz07's Avatar
kacz07
Results!? Intake results?!
Nice work. Glad to hear your car is doing well. Powdercoating looks siiiiiick.
Old Nov 10, 2010 | 05:32 PM
scmtkings4's Avatar
scmtkings4
good job man
get it tuned though. I think you'll see more improvement
Old Nov 10, 2010 | 05:36 PM
Nodata's Avatar
Nodata
Sexy
Old Nov 10, 2010 | 05:54 PM
singh's Avatar
singh
_______________
wow sounded like a nightmare just to install those things.. interested in seeing a dyno or some quarter mile slips to see if it was worth it
Old Nov 11, 2010 | 05:29 AM
ieatpelicans's Avatar
ieatpelicans
awesome job. you guys make me feel mechically inadequate.
Old Nov 11, 2010 | 05:40 AM
rich2342's Avatar
rich2342
What are the rest of your mods?
Do you plan to dyno with the newly added cams?
I've contemplated cams only as a build is far too expensive for now. Very interested in the gains and driveability. I think it would be advantagous for tracking in the high rpms.. Love to see a Dyno though..
Old Nov 11, 2010 | 05:50 AM
Row2K's Avatar
Row2K
excellent job, was there any particular reason you didn't go with anything more aggressive from Tomei, JWT, or BC ?
Old Nov 11, 2010 | 09:10 AM
PrimeX's Avatar
PrimeX
Wow, sounds like the headache from hell, but I hope it's worth it!
BTW- Left over pizza shipped to 77015 plz.
Old Nov 11, 2010 | 12:05 PM
rich2342's Avatar
rich2342
I just read Sash's cam test in the other thread.
I'm really curious to see your results when you have them.
Old Nov 11, 2010 | 01:58 PM
SexyRob's Avatar
SexyRob
I was worried about driveability which is why I didn't go with a more aggressive cam... I drive my car to and from work everyday so I didn't want something crazy.
plus I just have a fetish nismo parts...
supporting mods are:
K&N drop in panel and Z-tube
ported and polished / port matched plenum
5/8 spacer
strup coated headers
AAM highflow cats
Bassani Exhaust
Uprev Osiris
I also saw sasha's cam review and am kinda bummed that I didn't got with the JWT S1's they seem to have done quite well.
Old Nov 11, 2010 | 02:16 PM
ajcool2's Avatar
ajcool2
What kind of paint did you use? I have some extra timing covers laying around I may paint and sell.
Old Nov 11, 2010 | 02:17 PM
rich2342's Avatar
rich2342
Are you going to re-tune for the cam addition or did you do that already?
Plans for dyno?
Old Nov 11, 2010 | 05:23 PM
ajcool2's Avatar
ajcool2
Nevermind I fail at reading.
Old Nov 11, 2010 | 06:47 PM
SexyRob's Avatar
SexyRob
I plan on doing a dyno at a place I dynoed at a week ago so I can see what gains/losses were made and where.
once I get some more cash together I'll probably drive down to austin for a tune by uprev themselves..
Old Nov 12, 2010 | 07:46 AM
failsafe306's Avatar
failsafe306
If they are busy, I'd love to get a crack at tuning a cammed NA VQ
(I'm still an UpRev dealer/tuner)
Chris
Old Nov 12, 2010 | 08:15 AM
Zazz93's Avatar
Zazz93
Welcome to the club, "Fail, Fail, Win Installs". Had some similar issues this last week doing the same. When I put my cams in about two months ago I noticed I missed the valve clearences on a couple of valves but otherwise ran great. I did a couple of track days on it but finally started to feel embarassed about the ticking and decided to take it apart to correct. When I finished I had cut my valve cover gasket and somehow the cam position sensor (that hadn't been touched) just gave up and started throwing the P0011 code. I've started to use glue to hold the gasket on the valve cover to finish the install (it not a strong bond but enough for the install).
Old Nov 12, 2010 | 10:01 AM
SexyRob's Avatar
SexyRob
yeah lol, we put some goop (rtv/permatex stuff) to hold the gasket in because I cut that gasket.
I checked a couple clearances and assumed everything was good. how bad was your ticking? mine seems about the same as stock.
I checked stock clearances and it was .28 for intake and .3 for exhaust and after I put the nismo cams in they were within the spec listed on the box, can't remember off hand what it was.
