Exhaust Drone Fix
Old Nov 24, 2010 | 08:22 AM
Sportsfan811's Avatar
Sportsfan811
Default Exhaust Drone Fix
I have the motordyne v1 shockwave with tps and it drones alot in my cabin has anyone tried putting dynomat or some material in the cabin to reduce the noise and if so where exactly did you put it because its hard to locate the worst part of the drone and what interior parts might be shaking?
Old Nov 24, 2010 | 08:38 AM
gonZo50Z's Avatar
gonZo50Z
Seems like lots of people have had rattle issues and have tried a number of things to varying degrees of success. Maybe you should swap those Berks for ART Pipes?
Old Nov 24, 2010 | 09:43 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
You can also switch out your V1 axleback section for the V2 axleback section. That will kill the drone.
Give me a PM if you would like to find out more.
Old Nov 24, 2010 | 10:50 AM
viceversa's Avatar
viceversa
I was able to take away at least 80% of my drone by swapping my resonated module with a straight pipe module for the XYZ pipe.
Old Nov 24, 2010 | 10:05 PM
Sportsfan811
Well I have the straight pipe module already vice lol. Yeah I might switch to the art pipes that might reduce the drone anyone tried this? My main concern in the rattly I hear of what im guessing is the strut brace tower and just the plastic parts on the inside of my car.
Old Nov 24, 2010 | 10:08 PM
Sportsfan811
Hydrazine have you heard of the v1 shockwave setup hitting the sway bar at all could that be part of the sound im hearing?
Old Nov 25, 2010 | 12:07 AM
terrasmak's Avatar
If its not positioned perfectly it hits the diff on the lower left corner. Its just a matter of loosening the V band clamp and twisting the exhaust.
The resonated module helps with drone, stock cats help a lot. Then swapping to the Gamma or other muffler section is the best move, and in 2 minutes you can swap back to shockwave for the track.
Old Nov 26, 2010 | 09:09 PM
Sportsfan811
That's true, so there's no easy fix like adding dynomat to certain parts of the car to decrease the rattle?
Uriyo_
Sep 8, 2021 08:46 AM
sales@czp
Sep 23, 2019 03:30 PM
Cashwin
Oct 1, 2015 06:36 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
