Test Pipes rubbing Cat Heat Shields - Remove them?
Old Dec 18, 2010 | 09:38 PM
RetchedOne's Avatar
RetchedOne
Exclamation Test Pipes rubbing Cat Heat Shields - Remove them?
So i installed my test pipes, and the resonators touch the cat heat shields... Not bad, but enough to where I can already tell that they will rattle...They are Ichiba test pipes.
Can I remove the heat shields?
I mean, i know they come off, but.. Can i remove them as i dont have cats anymore? I doubt the resonators will get hot enough to warant them...
Would like to do this while the car is still on the jack stands...
Old Dec 18, 2010 | 09:59 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
take them off. /thread
Old Dec 19, 2010 | 09:55 AM
Boba's Avatar
Boba
If EVERYONE who installs test pipes get the rattle, then take them off. /thread
HOWEVER, there's only a select few that actually get it.
What does this say? The order of torquing down all the exhaust bolts are wrong and/or the Y pipe is hanging a little low, causing stress on the test pipes.
I wouldn't take off the heat shields. If others managed to not have problems with test pipes, then you can too. One less component from car taken off = one less problem to worry about putting back on later...
Edit:
Solution: Take off your catback, torque down the Y pipe first with even force at opposite flanges, then tighten. NOW, get a wooden shim or another floor jack or whatever you have and hold up the Y pipe since right now, your Y pipe is hanging down from not bolting up to midpipe. Then put on the midpipe, torque down with even force, then tighten etc... Basically, what you want to do is torque down the Y pipe to Mid pipe bolts at level height. You don't want either one hanging as it will cause uneven stress on the bolts. Last, put on muffler.
Should take about 30 mins. Keep us updated!
Old Dec 20, 2010 | 07:30 PM
xthejokerx's Avatar
xthejokerx
so did you fix the problem??
Old Dec 20, 2010 | 08:17 PM
RetchedOne's Avatar
RetchedOne
I took the heat shilds off.. But with my RS*R Exhaust, the car is way too loud in the interior... Cat's going back on...
sales@czp
Sep 23, 2019 03:30 PM
issyz
Jul 2, 2017 03:04 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
codek
Sep 28, 2015 03:03 AM
