Weapon R Intake
http://cgi.ebay.com/ebaymotors/WEAPO...Q5fAccessories
I searched around and I didnt find anything on this intake.
Does anybody have it or have herd anything about it?
Any feedback is appreciated, thanks
go with injen
I had a pop charger and due to all the people here saying 06 airbox and a drop in is best, I swapped. I think the pop charger was better. I have a Varis duct and had air duct running straight to the airbox and also straight to the filter on the JWT.
I decided since I think the JWT is better than stock, then a CAI would be better.
Right now, I have the B-line intake. I can change from CAI to SRI and it sounds great. They used to be a vendor here. For the price comparison, this is a much better option than the Weapon R. Honestly, go cheaper and get the JWT. There isn't much difference if any between it and this CAI other than this intake sounding much louder.
http://cgi.ebay.com/ebaymotors/NISSA...Q5fAccessories
Overall, I don't think there is a lot of difference between any intake for these cars but I do think the open filters seem better if and when you can get cold air to them.
Please post the proof with the paremeters of the dyno. Was the hood open/ closed cooling air or no cooling air. This does make a difference with the JWT. Hood open with air circulation similer to normal driving conditions will show much difference than sitting still injesting 170 degree air.
Not quality, made my car slower down the 1/4mi. What a waste of money!
Stop giving out bad advice...
What do you know? Nothing...
Rob is the man.
Hood was open brotato.
Annndddd here's Rob's proof:
http://xbcustoms.com/Rob/intakedyno.htm
How he did the test:
YUP, EVERYONE BUY THE JWT!!!
Rob is the man.
I setup a methodology of testing: I needed some guidelines to adhere to in order to achieve accurate results and be able to get reliable
data. I got in contact with people more knowledgeable than myself with the way this sort of testing should be done and established this set of
testing rules. The people involved in creating this set of rules included: the manufacturers of the intakes, a certified infiniti tech, multiple
people on the G35driver and my350z Forums, and myself.
I tried to create a level “playing field” for all the intakes by keeping the variables to a minimum.
- The Vehicle remained strapped during the entire 6 hour testing period
- The dyno cooling fans were blowing on the car at a constant speed; the angle in which they blew also stayed the same.
- The hood remained open, to help rule out heat soak on the intakes
- Before switching each intake the battery cable was disconnected and the brake pedal was pressed and held for 10 seconds (this is the
known procedure for clearing the g35/350z ECU)
- Each intake was given the same amount of time to cool down, and the same amount of learning time (around 30 minutes cool down, 10
minutes learning)
- The ambient temperature range and humidity was relatively stable at 77 – 81 degrees F and 20 – 22 %, respectively
- The intake air temperatures were monitored to make sure each intake wasn’t suffering from heatsoak
- Each intake was given at least 3 good runs, if there were any spikes or oddities it was discarded and ran again. By the 3rd run heat soak
became a variable. The first and second runs were always the highest.
- Engine Coolant temps were also kept stable between intakes
- Each intake was to be data logged with Osiris Cipher
- Each intake was to have a sound recording done (2 feet away from engine, same location every time)
minutes learning)
