Anyone have a DIY to replace top o2 sensors?
Old Mar 22, 2011 | 03:35 PM
dfresh713's Avatar
dfresh713
Master
Default Anyone have a DIY to replace top o2 sensors?
Got a code and need to replace the top driverside o2 sensor. Did a search and didnt come up with anything. Anyone have a diy?
Old Mar 22, 2011 | 04:45 PM
terrasmak's Avatar
Unplug sensor, install 7/8 th wrench or O2 sensor socket over the 02 sensor and twist CCW. Then follow the direction in reverse for the install.
Old Mar 22, 2011 | 07:49 PM
There are several DIY header and test pipe install threads. Same deal.
NOTE: For header install I recommend removing sensors AFTER catalytic converter is removed. This gives you lots of leverage with catalytic converter on a bench or secure in a vice. Here you may want to remove sensor with catalytic converter in place.
Old Mar 23, 2011 | 12:03 PM
bbs350z's Avatar
bbs350z
may have an easier time working from the top. make sure you get the correct sensors. revup's came with factory widebands and had different connections, so it it motor year specific
Vigman
Nov 17, 2015 04:34 AM
350Z Project X
Oct 17, 2015 05:16 PM
Dust
Sep 15, 2015 02:08 PM
Dust
Sep 15, 2015 08:28 AM
