Question with nismo s-tune exhaust
Old Mar 25, 2011 | 09:01 PM
jobimg's Avatar
jobimg
Default Question with nismo s-tune exhaust
i didn't know that nismo s-tune muffler and mid-pipe would fit on stock Y pipe "bolt on". Is this really true?
Thanks
Old Mar 25, 2011 | 10:20 PM
The s-tune is a cat back exhaust. Replaces everything from the catalytic converters back.
Old Mar 25, 2011 | 10:27 PM
Any particular reason you created 3 threads on the same subject?
Old Mar 26, 2011 | 12:54 AM
terrasmak's Avatar
Yes the muffler and midpipe will bolt to the factory y pipe. Most of the power you gain is actually from changing the Y pipe to a quality one like the motordyne XYZpipe.
Old Mar 26, 2011 | 02:52 AM
Z04's Avatar
Z04
https://my350z.com/forum/search.php
Old Mar 26, 2011 | 09:37 AM
tylerxfire's Avatar
tylerxfire
yes it will work...one thing i am very persistent on is what a peice of **** the nismo y pipe is...it caused cracking issues through my exhaust when i ran it..i cracked 2 sets of test pipes and 1 mid pipe...If the nismo y pipe is used with stock cats it is ok but if used with high flows or test pipes this problem is bound to happen...The nismo y pipe is a hair shorter which in return i beleive causes stress on other parts of the exhaust...If you are running high flows or test pipes i recommend leaving the stock y pipe until you can get a different y pipe...motordyne xyz is a great choice!! i ran one with the resonator attachment to cut out any rasp i had which it did flawlessly and gave a nice power gain
Old Apr 29, 2011 | 10:23 PM
mgrotel's Avatar
mgrotel
What's the inside diameter of the nismo exhaust?
Old Apr 30, 2011 | 10:09 AM
dcains's Avatar
dcains
It's ~3".
issyz
Jul 2, 2017 03:04 PM
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
