07-08 HR y-pipe or MR y-pipe ??
Old May 11, 2011 | 03:56 PM
Z DominateR's Avatar
Z DominateR
Default 07-08 HR y-pipe or MR y-pipe ??
I need your guys advice not really to experianced with aftermarket y-pipes but I'm planning on getting an 07-08 HR y-pipe or should I go with the Megan racing but of these are around the same price range. Let me kno what you guys think
Old May 11, 2011 | 04:55 PM
phreaktor's Avatar
phreaktor
Design Engineer
M2 (Made by Megan) $70 shipped on ebay. Y-pipe makes almost no difference at all in sound or performance BTW.
Old May 11, 2011 | 09:20 PM
hellsoldiers08's Avatar
hellsoldiers08
idk i would beg the differ, if you have bigger diameter test pipes and sam for catback exhaust this could cause a bottle neck...
Old May 12, 2011 | 03:39 AM
kramykram's Avatar
kramykram
if your going to order a ypipe order a real one. jic, motordyne, aam, stillen. something good. its cheap crap like that, that has killed the market.
Old May 12, 2011 | 05:36 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
all depends on the rest of your setup
a Y pipe absolutely does have a large impact in performance as well as sound...depending on what the rest of the setup is.
Old May 13, 2011 | 04:17 PM
LoSt's Avatar
LoSt
If you plan on keeping the stock muffler, then get the HR y-pipe. If you plan to upgrade exhaust then get aftermarket (megan, whatever) y-pipe. Otherwise the outlet of the megan, et al will be much bigger than the stock mid-pipe.
Old May 14, 2011 | 03:48 PM
Z DominateR
^^ thanks guys for the advice really helped on my decision all I have to do now is order it =)
Old May 14, 2011 | 04:29 PM
phreaktor's Avatar
phreaktor
Design Engineer
wat
The only pipe I have seen that looks any different than the others is the ichiba I think? Its angled and straighter... The only place I can see any difference with the others is how the welds are smoothed out inside.
Edit: its the AAM...
Old May 19, 2011 | 04:29 PM
grizz311's Avatar
grizz311
Originally Posted by phreaktor
wat
JIC has one too. Theirs is 3 inches, and im not sure how wide the oem one is.
Old May 20, 2011 | 05:39 AM
Z1 Performance
Former Sponsor
wat
there are a number of different, unique Y pipe configurations offered by various manufacturers. To name a few
Ultimate Racing
Sunline Racing
Mines (incorporates midpipe)
Old May 20, 2011 | 05:57 AM
gordenZ's Avatar
gordenZ
correct me if I'm wrong ... but if the ID of your output is 2.5" from test pipe all the way down to your exhaust, and you're not using resonated TPs or HFCs, it shouldn't matter. Piping is piping. As long as there is the correct diameter that won't constrict the flow through the entire system, then they're just pipes.
Keep in mind . You also pay for what you get. A cheap Y pipe is gonna work the same damn way as a 300 dollar one if the spec measurements are the same. But it's about quality, you run higher rinks of having the welds or material crap out on you with the 70$ ebay pipe than a more sophisticated brand pipe.
That is just me of course. Without resonators or HFCs, a pipe is a pipe.
NYT
East Canada
Sep 23, 2015 05:32 AM
CJs_Z33
Sep 18, 2015 12:06 PM
