The perfect sounding/flowing exhaust
Retired Admin
I actually looked for an exhaust that was relatively quiet, had the look of the OEM, flowed better, etc much like you. I currently have the APS's 2.5" true dual and it fits my criteria (very similar, if not the same, to your criteria).
http://www.mzmperformance.com/aps-35...st-system.html
Your custom exhausts look very nice. In for sound clips.
looks nice! the welds look sexy as well. just wondering if you saw the vibrant performance resonators though?
http://vibrantperformance.com/catalo...oducts_id=1702
seems this was kinda what you were looking for?
I have never heard the Borla exhaus on the VQ, I am sure it sounds great. The other very important fact that I did not mention is that my exhast must bolt up to the OEM Y-pipe. This is how the turbo kit is built.
I did have a look at those, but thought that the body length was too short for a 5" OD resonator. I also had a look at the Vibrant "Ultra quiet" series, and thought that the may be a bit on the small side.
Yeah, it's a heavy duty unit. Here is the thread:
https://my350z.com/forum/forced-indu...-inside-3.html
I have not had even the slightest hint of wheel hop since I installed it. This includes the drag strip.
on
Do you find this to be abnormal? I've had the whole APS single turbo setup including the exhaust with testpipes and it's quieter than stock...
Retired Admin
I've heard this APS 2.5" TD exhaust (I believe there's at least one other version of the 2.5" TD) on a APS TT 350Z, Vortech 350Z, and my Z with juice. It's definitely quieter than stock on all applications in most situations (daily driving, not WOT).
on
Hey Sasha....any reason you didn't go with a 5" diameter resonator with 3" inlet/outlet to avoid the modifications you had to do?
Do you have a part# for the one you used?
This is the one I have on the car now:
http://www.magnaflow.com/02product/s...e=main&id=9102
If I was to do this over again (for a customer), this is the muffler I would use in the back:
http://www.magnaflow.com/02product/s...e=main&id=9059
I have the same one now (size wise) but the inlet/outlets are configured differently.
#38
I took about 1" off, making it a 5" resonator on the side that was cut. You can see in the pictures where it sits, I would say it is about 2" downstream from the turbo. It just fits between the rear skid plate, and the rear sway bar.
Looks like the weather will get better (6 straight days of rain now) tomorrow, so I will try to get a sound clip made.
