Using V-Band clamps for exhaust silencers??
Old Jun 14, 2011 | 10:38 AM
djtimodj's Avatar
djtimodj
Default Using V-Band clamps for exhaust silencers??
Just a quick question, does any one on here use an exhaust that uses v-bands in stead of flanges?
I have a custom true dual that I needed to added extra silencers to reduce decibel output from 112dB to <105dB. I really would like these to be removable so v-bands look like my best option so far.
The extra silencers will be in the centre of the exhaust in the prop tunnel.
Are v-bands as strong as a bolted flange joint?? Any one think I'll have any problems etc?
Thanks.
Old Jun 14, 2011 | 11:26 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
I've done it before and it works just fine.
Old Jun 14, 2011 | 12:06 PM
terrasmak's Avatar
Been running 2 V band clamps on my motordyne exhaust for almost 3 years now. I do suggest having an extra clamp if you remove and install them often, the threads like to strip out if you tighten them to tight. I also work on aircraft and use them at work all the time, the thread strip from time to time, just like a flange bolt seizes or breaks.
I change my exhaust at the track all the time, i just smoked my first clamp this weekend. Need to call Hydrazine and order a couple extra's.
Old Jun 14, 2011 | 12:40 PM
djtimodj's Avatar
djtimodj
That's good to hear then as I'm looking at adding two silencers on v bands and keeping the straight pipes for road use and swap in the silencers for the track.
I'll post up when I get some!
Old Jun 14, 2011 | 01:25 PM
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
To avoid stirpping the threads, you can always put a bit of grease on the thead when you put the clamp on. Stainless steel V-bands are bad for this (stainless in general), and a bit of thread lube will go a long way.
Other than that they work great.
Old Jun 14, 2011 | 03:49 PM
terrasmak's Avatar
Antisieze is much better for this, should have mentioned it earlier.
Old Jun 16, 2011 | 11:06 AM
rcdash's Avatar
rcdash
You can also use two nuts on the v-band clamp instead of one. That distributes the load across more threads. I wish I could find longer longer nuts but two together seem to work fine. It's also a good way to keep using a v-band that has a stripped couple threads. The two nuts will get you past the stripped point. Can you tell I've taken off my v-bands like 100 times? Love the MD exhaust design - easy to mix and match components!
Old Jun 18, 2011 | 04:48 PM
SoCal07HR's Avatar
SoCal07HR
Yep I just got my Motordyne exhaust the clamps work great.
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
Li1ag
Sep 28, 2015 02:07 PM
