Jet-Hot coating worth it?
Old Sep 26, 2011 | 03:48 PM
unvmyg35's Avatar
unvmyg35
Default Jet-Hot coating worth it?
I'm getting a Vortech system installed in a few weeks. (my build here: https://my350z.com/forum/forced-indu...ech-build.html )
I'm installing a set of Stillen stainless headers with this build. I'm contemplating getting them jet-hot coated.
Is it worth getting them coated? Pro's and Con's?
Old Sep 26, 2011 | 06:23 PM
Rubidium's Avatar
Rubidium
I've only heard it's a lot better than ceramic coating, contains the heat better.
Old Sep 27, 2011 | 01:44 AM
unvmyg35's Avatar
unvmyg35
Just edited post. Forgot to mention these are stainless headers.
Old Sep 27, 2011 | 08:20 AM
eltness350's Avatar
eltness350
The Untouchable
the vortech wont produce the same type of heat as a turbo kit, i have my manifolds done and it was pretty reasonable..about 200 if i remember, u dont "need" it but if you have the extra cash............or save it for a tune
Old Sep 27, 2011 | 09:17 AM
Ruthless18x's Avatar
Ruthless18x
I just did ceramic. Not only for the heat but for corrosion protection, I hate rusty cast manifolds.
That wouldn't apply to sst headers though, and as said above, sc's don't generate the same temps.
Old Sep 27, 2011 | 10:37 AM
unvmyg35's Avatar
unvmyg35
Thanks guys.. I rather save the oney for something else!
Old Sep 28, 2011 | 08:18 AM
Resmarted's Avatar
Resmarted
I would get it jet coated. Yes it's not a turbo manifold where keeping the heat on the inside can improve power output, but it will prevent excess heat in your engine bay which is always good. If the jet coating is over about 150$ I'd recommend buying some DEI exhaust wrap and just wrapping your headers yourself. It's a simple and easy DIY if you have the headers out of the car.
It's not necessary and you will get along fine not doing it, but it's something I'd do. It's little details like that that can bother me on cars, or make a car just that much better in my opinion.
Old Sep 28, 2011 | 09:20 AM
gabe3d's Avatar
gabe3d
My first header i installed were not heat wrapped, the second set were wrapped using Tomei and DEI wrap and there was a big difference on how fast the intake heat soaked. Nothing I logged but just from observation. My current set of headers (LTH) are Fireball Coated which is the same as Jet Hot and I don't regret it.
Old Sep 28, 2011 | 12:40 PM
Road Warrior's Avatar
Road Warrior
i did mine and it was money well spent. as mentioned, if your doing a ss header install then why would you not want to do this? sure its a few bucks, but i believe the benefits are well worth the cost. check their website for pro's and con's...they do excellent work.
Old Sep 29, 2011 | 04:19 AM
unvmyg35's Avatar
unvmyg35
I decided to ask Rob @ ZCG and he said, "not worth it." So I'm kind of at a loss here.
I was quote $190 from Jet hot coatings. I'm trying to find more research on this. Any links would be helpful, thanks.
Old Sep 29, 2011 | 02:40 PM
Road Warrior
i suppose if you are fi then you would have higher header temps that would require the more expensive jet hot coating...be sure to get the right coating for your application.
as far as is it worth it or not....google is your friend. at least then you will have a better idea of whether or not it is worth it to you.
good luck
