How to get cold air from JWT Popcharger ?
Old Oct 1, 2011 | 11:49 PM
toka350z's Avatar
toka350z
Default How to get cold air from JWT Popcharger ?
Hey everybody. I am a new member here and i am going to install an intake this week. I was researching on the pros and cons of the JWT Popcharger and i saw in some posts that i takes hot air from the engine. And i searched to on the K&N Cold Air Intake. Didnt find any pros and cons from the CAI. I decided to go with the JWT Popcharger because i didnt find anything on the K&N CAI. Any help about the CAI will be appreciated.
Old Oct 2, 2011 | 02:36 AM
JCITY's Avatar
JCITY
Good choice--JWT!...has a neat heat shield.
I would'nt worry much about the engine heat.
Its a bolt on,a little more power,good price&quality---sounds good!
Old Oct 2, 2011 | 02:42 AM
r_seng's Avatar
r_seng
Buy the Typhoon scoop
Old Oct 2, 2011 | 04:02 AM
silvertouringz's Avatar
silvertouringz
here's my setup..
Attached Thumbnails How to get cold air from JWT Popcharger ?-imag0348.jpg   How to get cold air from JWT Popcharger ?-imag0349.jpg
Old Oct 2, 2011 | 05:05 AM
abarclay's Avatar
abarclay
This might help ya:
https://my350z.com/forum/2489732-post9.html
Old Oct 2, 2011 | 08:04 AM
Old Oct 2, 2011 | 09:27 AM
ImWeeZzel's Avatar
ImWeeZzel
That's a simple bolt on, shouldn't be too hard
Old Oct 2, 2011 | 01:06 PM
terrasmak's Avatar
Drag car get something different, roadcourse/autocross JWT is probably the best solution.
Old Oct 4, 2011 | 11:00 AM
Itzcashew's Avatar
Itzcashew
Popcharger soaks in way too much heat.
Stillen is better + http://www.thezstore.com/page/TZS/PROD/350z09b/11-2960
Old Oct 4, 2011 | 12:56 PM
Rubidium's Avatar
Rubidium
You could get the COBB Post MAF silicon air pipes then the JWT popcharger. The silicon hoses will block a lot of that heat.
Old Oct 4, 2011 | 07:32 PM
terrasmak's Avatar
Blind leading the blind, can either of you back anything up ? Doubt it, but i would love to hear it.
Old Oct 4, 2011 | 09:19 PM
Rubidium's Avatar
Rubidium
I'm sure you would, the silicon hoses don't induce the heat as easily as a metal pipe; is there some cold hard facts on this not really. So yes blind leading the blind.
Old Oct 5, 2011 | 01:45 AM
terrasmak's Avatar
The OEM piping is plastic, either way the air in not in the intake track long enough to heat up. You have to figure that 3.5 liters of air X RPM are moving thru the intake track while the car is running. Even if you had aluminum piping, with normal underhood temps the air is not in there long enough to heat up to make a significant difference.
The JWT setup is shielded very well for a moving car, it draws air equal to a CAI. The only time a JWT draws hot air is when the car is parked, that is why i asked it the car was for drag. It does take 5 to 10 seconds for the AIT sensor to change to the proper readings once the car starts moving.
Old Oct 5, 2011 | 04:03 AM
Rubidium's Avatar
Rubidium
So question for you, if you were to coat a aluminum pipe (ceramic or titanium wrap) could you still drop the temps or would it just be a waste? That was a pretty informational post, thanks. *not trying to sound like a jerk*
Old Oct 5, 2011 | 07:13 AM
terrasmak's Avatar
Minimal drop in temp, to the point the difference wouldn't be noticable to the AIT sensor. If the intake piping was 6 inches closer to the headers, it would probably be a noticable difference.
