87mmFT Throttle Body Anyone?
Old May 30, 2012 | 06:20 AM
  #101
Torgus's Avatar
Torgus
Originally Posted by juicinjake
im gonna look into this. there was a guy that posted up that had an 09 maxima tb on an 02 maxima ecu. this swap seems to be much more common and documented by those guys. personally, im much more interested in getting the 87mm maxima tb to work for simplicity's sake than i am the LS2... unless somehow magically there is one that just plugs in and works... i am not really looking to experiment since im daily driving the car.
Wiring up the 2k9 is simple and documented in this thread. I am pretty sure I posted up the pic on page 1. The 5mm gain is rather small and the cost isn't worth it imo. From my experience finding the 2k9 tb and wiring plug sperate from the whoel engine harness isn't the easiest. Granted you can solder to the connection points and fill the plug hole most people get scurred of that stuff.
If you were getting a custom IM built then going with it would be a no brainer, otherwise not worth it.
A 90 or 100mm DBW TB with no codes or driveability issues would be nice...
Old Jun 6, 2012 | 04:18 PM
  #102
kacz07's Avatar
kacz07
...and bump.
Old Jun 8, 2012 | 10:38 AM
  #103
Torgus's Avatar
Torgus
and nothing will ever happen with this like every other TB thread. Which is a real shame as there are proven gains with the larger TB.
Old Jun 10, 2012 | 08:54 PM
  #104
CLyons0203's Avatar
CLyons0203
Why do you think a VQ35DE would need a 90mm throttle body?
Old Jun 14, 2012 | 09:42 AM
  #105
Torgus's Avatar
Torgus
because SG proved it provided great gains...
also a certain altima is running around NY with an ls2 tb and a 4'' intake over 300whp stock cams.
Old Jun 14, 2012 | 10:50 AM
  #106
juicinjake's Avatar
juicinjake
im gonna see if street solutions can make their intake with a 90mm ls2 flange. i really like their intake, with the velocity stacks and port matched runners. i can make my own 4" intake if I have to, or we can do a group buy and get someone to make them for us perhaps... im an ee... i could probably figure all this wiring stuff out, but im super busy at the moment. how did the altima guy get it to work?
Old Jun 14, 2012 | 08:40 PM
  #107
CLyons0203's Avatar
CLyons0203
http://www.hitachi-automotive-la.us/...et_Catalog.pdf
Old Jun 15, 2012 | 11:37 AM
  #108
SurraTT's Avatar
SurraTT
not on stock cams.
older DE can do 300 with aftermarket cams.
older de with cams and 4" should be 310ish depending.
09 max with stock cams w4" is 300. with cams_____ unknown as of now
Old Jun 15, 2012 | 12:48 PM
  #109
CLyons0203's Avatar
CLyons0203
The 06-10 M45 and FX45 both have larger throttle bodies just like the 09 Maxima, although the part numbers are different.
Old Jun 15, 2012 | 12:49 PM
  #110
SurraTT's Avatar
SurraTT
The 06-10 M45 and FX45 both have larger throttle bodies and the harnesses are the same. Only thing needed would be an adapter plate.
what size?
Old Jun 15, 2012 | 01:17 PM
  #111
CLyons0203's Avatar
CLyons0203
same size as the 09 Maxima unit
75mm outlet 80mm inlet
Old Jun 19, 2012 | 08:57 AM
  #112
Torgus's Avatar
Torgus
Originally Posted by SurraTT
not on stock cams.
That is arguable. They gained 25whp removing the top 1/2 of the stock IM. Yes they had aggressive cams at that point. IMO it would still help w/o cams. Maybe not 25whp but you would get something.
You proved the 4'' intake has great gains w/ a tune.
It just makes sense that if you could greatly improve the airflow from the TB to the valves you would get great gains as well and the SG top popping reinforces that. The 1st step is a larger TB that matches the size of the 4'' intake right?
What we need imo is a log style IM with ls2 tb and internal VSs with short runners.
edit: as I have said before you really need to cam that bish
Old Jun 19, 2012 | 09:21 AM
  #113
SurraTT's Avatar
SurraTT
I was referring to that altima, hes doing 300+ hp with aftermarket cams
Yeah even with stock cams there should be some gains, but for all the work and $ on a stock cam motor hardly no one will want to spend that. I beleive the older DE motors love gobs and gobs of air, thats why a gutted manifold (FWD) has huge gains. But on the HR headed motor the gutted manifold dont do much at all.
IMO a larger intake will help most everyone out n/a that is. That's the most affordable and easy to do, ofcourse requires tuning, but that's a giving.
I thought about trying that test on my car, but being FWD it would be very dangerous to do on the dyno.
Old Jun 19, 2012 | 07:08 PM
  #114
CLyons0203's Avatar
CLyons0203
Every dyno I have seen of the street solutions intake manifold has shown a loss in horse power. I have a guy that is going to make a plate to put the larger 09 maxima tb on the G35 stock manifold. I'm going to test that out before I see about going larger
Old Jun 19, 2012 | 07:57 PM
  #115
juicinjake's Avatar
juicinjake
were they just bolting it on and dynoing or actually tuning on it. Even the kinetix velocity had gains above 6000 and nothing everywhere else. what tb did they use on the street solutions intake?
Old Jun 20, 2012 | 10:07 AM
  #116
Torgus's Avatar
Torgus
Cosworth is very similar.
That being said look what ITBs do for this engine.
What we need is a proper designed IM imo.
Old Jun 20, 2012 | 12:15 PM
  #117
CLyons0203's Avatar
CLyons0203
bolting it on and tuning it. I dynoed it myself against a stock manifold with space. using the oem TB. CIN motorsports tried what they knew, but it never made any gains.
Old Jun 20, 2012 | 08:27 PM
  #118
DarkZ03's Avatar
DarkZ03
We need an HR style manifold with twin TBs, that should wake it up!
Old Jun 21, 2012 | 01:28 PM
  #119
Torgus's Avatar
Torgus
We need a log style IM with inter Velocity Stacks with a nice large TB if you ask me.
Carbotron will sell you one like SG for $2000ish
Old Jun 21, 2012 | 06:26 PM
  #120
rich2342's Avatar
rich2342
Why don't don't we recruit Tony from motordyne to come up with something.. Obviously there is interest and we all know the R/d M.D does..
