Sheered Catalytic Converter Bolts
Old Mar 10, 2012 | 11:58 AM
anaden's Avatar
anaden
Default Sheered Catalytic Converter Bolts
Ladies and gents, was trying to install my new exhaust on today, and encountered a problem. While removing the old y pipe i sheared one of the bolts coming from cat converter to the y pipe. Can anybody recommend the best way to remove this bolt from the cat?
Old Mar 10, 2012 | 01:47 PM
R350Zz33's Avatar
R350Zz33
drill it
Old Mar 10, 2012 | 07:58 PM
Bmurray350z's Avatar
Bmurray350z
the stationary bolts? same thing happened to me. just put an open ended wrench around the screw and just bend the **** out of the screw and in my case it broke the welds loose on the other side and popped off. then just go buy another one at your local auto store!
Old Mar 10, 2012 | 10:27 PM
anaden's Avatar
anaden
ok, so are these bolt only welded on one side ie the side facing the front of the car? So if i cut the head off it should come out?
Old Mar 11, 2012 | 08:56 AM
anaden's Avatar
anaden
ok peeps, got the bolt off in 2 minutes, get a angle grinder and put a cut into one side of the flange (without damaging anything of course) and then the bolt comes out with a simple tap.
Old Aug 15, 2013 | 07:49 AM
sry110's Avatar
sry110
I started a similar thread today but unfortunately did not see this one first. So you actually cut into the flange? Or did you cut into the head of the stud where it presses into the back side of the flange?
@ Bmurray....think you got lucky with that approach or are you pretty confident it would work?
And anyone happen to know the part number and/or size+length of that stud so I can go buy it ahead of time?
AbrasiveRaysive
Sep 20, 2021 02:29 PM
sales@czp
Sep 23, 2019 03:30 PM
