APEXi ECV
Old Mar 18, 2012 | 02:21 AM
BlaQ350z's Avatar
BlaQ350z
Default APEXi ECV
I got a new exhaust setup (Motordyne ART pipe, Shockwave V2) but in order to pass my yearly vehicle inspection, i have to pass a sound test (which is basically a guy standing behind your car asking to rev your engine), they are really picky about sound.
Anyway, i have researched the APEXi ECV as much as i can but i fail to get a definite answer from anyone on what size matches my exhaust piping. Here is a link to the product: (surprisingly, very few people here know about this ECV)
http://apexi-usa.com/shop/index.php/...rol-valve.html
My exhaust is 2.5" = 63.5mm
The sizes available for the ECV are 61mm and 67mm
I received a response from APEXi themselves and they stated that the 61mm ECV has a valve-plate diameter of 58mm (2.28") and that as long as i have clearance for the valve plate, i should be fine.
I am not worried about the valve plate, i am worried about the flange fitting with my setup more.
Any input from anyone on this?
Has anyone installed one of these? what size?
I don't want to pull the trigger until i get some kind of definite answer since i will be forced to buy two of them.
Thanks in advance
Old Mar 18, 2012 | 08:59 AM
F2CMaDMaXX's Avatar
F2CMaDMaXX
This may be of some use to you;
http://youtu.be/5QqX6dKy2os
However, this all depends on where you're thinking of fitting it, the ART pipes and Shockwave system changes pipe diameter 3 times from the front to the back.
If i were you, i'd spend the money on the Motordyne "solution" by getting the HFC/resonator combo for the shockwave system, v-band, very easy to swap in and out.
The other thing is, depending on the rules, if you keep the revs low and/or only rev slowly, the shockwave system won't be as loud.
Old Mar 19, 2012 | 10:55 PM
BlaQ350z's Avatar
BlaQ350z
I saw this vid before, but unfortunately does not answer my question.
I know some people on here have it, but no one put pics of installation or answered the size differences.
I will also look into the HFC, but i don't know if it will be quiet enough to buy. I heard that this ECV really makes the sound stock.
As for the revving part, the guy makes sure you really give it alot of gas, i feel sorry he has to breathe all those fumes lol
Old Mar 20, 2012 | 05:34 PM
F2CMaDMaXX's Avatar
F2CMaDMaXX
Read the description in the vid, it helps somewhat.
The HFC/Resonator combo should knock it down enough for the test.
The pipe size differences depend highly only where in the pipe your'e going to put it, i already explained where the sizes change.
Dr.Paulyy
Jul 29, 2019 07:45 AM
GTO2350
Aug 21, 2004 11:47 AM
silverstoneTT
Jun 11, 2004 12:47 PM
drivenCSZ
Apr 4, 2004 03:06 PM
valuetl
Mar 28, 2003 05:45 AM
