Quick question on exhaust sizing
Old Mar 22, 2012 | 08:34 AM
Mike Anthony's Avatar
Mike Anthony
Default Quick question on exhaust sizing
I have a NISMO
Stock exhaust w/ AAM HFCs
It was tuned and there is only a slight amount of rasp left.
I want to replace the Y-Pipe with a resonated XYZ pipe and see what that does.
My only concern is, the 3 inch outlet of the XYZ pipe will be mating against a 2.25 inch inlet of the mid pipe.
Would it be acceptable to replace the midpipe with one that reduces down to 2.25 inch from 3 inch? Like more of a gradual reduction than the sudden XYZ 3 to the mid pipe 2.25?
I'm trying to keep the stock muffler because I want it to look stock, and not be THAT much louder than stock.
Old Mar 22, 2012 | 10:48 AM
The 0.25 inch difference is minor. Effect on exhaust volume and speed is inconsequential.
Old Mar 22, 2012 | 10:52 AM
doshoru's Avatar
doshoru
Another option is to get a Borla exhaust.
True Dual, so you don't need a Y-pipe at all.
It's resonated (no rasp or drone), is not much louder than stock, and looks close to stock.
Old Mar 22, 2012 | 11:20 AM
Mike Anthony
It's a .75 inch difference actually. I was thinking the XYZ pipe was 2.5 out but it's actually 3. I was thinking of maybe a custom mid-pipe with a gradual 3-2.25 reducer in it. Not sure if that would cost a lot or not... :/
I was thinking about borla... but it wouldn't look stock on a nismo. The nismo is open enough to see the muffler from behind, and it has big 4.5" tips on it.
Old Mar 22, 2012 | 11:38 AM
terrasmak's Avatar
Motordyne exits at 3 inch, stock midpipe is 2.75. It is really no problem.
Old Mar 22, 2012 | 12:23 PM
F2CMaDMaXX's Avatar
F2CMaDMaXX
The XYZ pipe with the resonator will kill off your rasp, almost guaranteed, it's a good pipe, mine is bolted to the stock mid section, don't worry about the size difference, it's minimal and as i said, the res will kill off the rasp you have.
Old Mar 22, 2012 | 12:29 PM
Thumbs down
Oh the story changes. 0.75 inches is a significant drop. Think about what this looks like inside the piping. Do not like this restrictive choke point.
Old Mar 22, 2012 | 12:38 PM
doshoru's Avatar
doshoru
Yeah, if it's really .75", that's huge. Going from a 2.25" diameter to 3" is almost double the area!
2.25" = ~4sq inches
3.0" = ~7sq inches
Old Mar 22, 2012 | 01:40 PM
Nismo1534's Avatar
Nismo1534
If you want the OEM look and no rasp, go with Nismo S-Tune OR Fujitsubo Legalis-R:
https://my350z.com/forum/nismo-350z/...the-nismo.html
Other good OEM-ish exhausts are DC Sports, Invidia Gemini, Tanabe....
https://my350z.com/forum/nismo-350z/...-exhausts.html
If I were you, I wouldn't waste my time spending the $415 on a resonated XYZ pipe, just to eliminate some rasp. I'd spend $800 or so on a full cat-back system that sounds good, improves performance, and has that OEM-style look. Last year, I was in this same boat (see Fujitsubo link above) and will be purchasing the Invidia Gemini this Summer, as it is a combination of all three areas (looks, sound quality, performance) at an affordable price.
Old Mar 22, 2012 | 05:05 PM
F2CMaDMaXX's Avatar
F2CMaDMaXX
OK, first off, the Y-pipe is the second most restrictive part of the exhaust system, with the cats being primary.
Secondly, the exit of the stock Y pipe is 2.5 inches, not 2.25.
There is no problem with the difference between 2.5 and 3.0, i'm not sure on the actual inlet of the stock mid pipe, just the exit of the stock y-pipe.
The XYZ pipe has been setup with the merge point at the optimum position for most power and torque, so you gain, not lose.
A full cat back will not gain you the power/restriction removal that the XYZ pipe will give you.
Old Mar 22, 2012 | 09:19 PM
R350Zz33's Avatar
R350Zz33
hr y pipe /thread
Old Mar 23, 2012 | 03:35 PM
F2CMaDMaXX's Avatar
F2CMaDMaXX
The HR pipe would work, but it's not great, it's the lesser of two evils, it's just not *as* bad as the earlier 350 y-pipe.
Old Mar 26, 2012 | 11:03 AM
Mike Anthony
So wait, the stock Y-pipe inlet is 2.75 inches? If so, I did not know that... In that case it would be fine.
Old Mar 26, 2012 | 11:35 AM
F2CMaDMaXX's Avatar
F2CMaDMaXX
Yup, and just for completions sake, i measured the inlet to the mid section over the weekend. The Gasket for the XYZ pipe was barely a quarter inch larger, if not a smaller amount.
Old Mar 26, 2012 | 07:14 PM
Mike Anthony
Meaning it would work?
Old Mar 26, 2012 | 07:21 PM
F2CMaDMaXX's Avatar
F2CMaDMaXX
Yes, exactly
Old Mar 26, 2012 | 07:23 PM
Mike Anthony
Cool. There is hope. I hope.
EnjukuRacing
Coupons
Sep 9, 2015 08:13 AM
NYGiants0186
Sep 8, 2015 10:37 AM
