Tunnel Stay Bolt Broke
Old Apr 16, 2012 | 04:24 PM
DR_350z's Avatar
DR_350z
Default Tunnel Stay Bolt Broke
Just received my new exhaust this week and finally had time to work on it. I just removed the old exhaust, but one of the 12mm bolts broke off of the Tunnel Stay when I removed it. The other 5 12mm bolts, and all 4 14mm bolts are fine. I tried drilling out the broken bolt without luck. Am I wasting my time trying to drill this bolt out or will I be fine without it?
Old Apr 17, 2012 | 06:55 AM
VO...'s Avatar
VO...
Administrator
I'm not exactly sure what a Tunnel Bolt is. Pics?
Old Apr 17, 2012 | 11:20 AM
F2CMaDMaXX's Avatar
F2CMaDMaXX
I think he's referring to the center exhaust hangar. The one just behind the center resonator.
I think you need to have something there, the next support is the rear muffler flange. Before that, it's hanging the entire Y pipe from the engine unless you're still using the gearbox bracket mounts. Either way, there isn't much support there, i'd recommend you continue trying to fix it.
Old Apr 17, 2012 | 02:07 PM
DR_350z's Avatar
DR_350z
Its the 'M' looking flat brace. The 3 12mm bolts are right in front of the rear wheel. Couldn't wait so I went ahead and re-installed without the one bolt. I don't think it will be an issue since all of the other bolts were fine. Just wanted to know if it is worth my time trying to drill out the broken bolt, or do you think it is fine as is?
Old Apr 17, 2012 | 08:05 PM
Itzcashew's Avatar
Itzcashew
I'd say remove it and get that to be properly bolted down. If not it may/may not cause any damage. But better to be safe than sorry.
Old Apr 17, 2012 | 08:08 PM
F2CMaDMaXX's Avatar
F2CMaDMaXX
Yeah, that bit helps with side to side movement and support, i'd get it done.
Old Apr 18, 2012 | 03:02 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
people remove that thing for exhaust installs?
I have done a handful of exhaust swaps and never even thought to remove it. It actually helps when you are by yourself.
Old Apr 18, 2012 | 03:52 PM
F2CMaDMaXX's Avatar
F2CMaDMaXX
Wait, he removed it? I thought he was just picturing the location of the hangar?
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Fixxxercask
Drivetrain
Sep 28, 2015 11:15 AM
