Fast Intentions HFC Gasket Question
Old Apr 23, 2012 | 08:56 AM
mike212's Avatar
mike212
Default Fast Intentions HFC Gasket Question
I purchased a used HFC for my 2007. Is there a gasket that needs to used between the manifold and hfc?
Fast intentions only provided a gasket for the hfc to y-pipe section. I am not sure whether high temp silicone alone will be good enough for the manifold to hfc connection.
Thanks!
Old Apr 23, 2012 | 09:01 AM
LMG_35C's Avatar
LMG_35C
yes indeed you need a gasket there. I had re-used the OEM metal gasket but my Berks came with a replacement fiber gasket as well.
Old Apr 23, 2012 | 09:10 AM
mike212's Avatar
mike212
It looks like 2007 and up uses an o-ring type of gasket that is designed for the OEM cat. It resembles the crush washer used in the oil bolt. Models prior to 2006 use an actual triangular gasket. I checked the Berk site and it looks like the shape of their gasket would not match at that connection. Does anyone have a suggestion?
These instructions came directly out of the FI install guide. They state that the o-ring gasket should not be reused but I am hesitant about leaving it as-is.
Old Apr 26, 2012 | 05:19 AM
mike212's Avatar
mike212
I got a CEL by using the silicone gasket maker. Can anyone recommend a good gasket to use for the cat to manifold location?
burglapfd
Dec 6, 2020 01:04 PM
