Question about my exhaust...
Old May 3, 2012 | 04:48 PM
Vandy-Z's Avatar
Vandy-Z
Thumbs down Question about my exhaust...
Ok so here is my set up.
Megan Racing Headers
Custom Resonated Y Pipe
Resonated Test Pipes
Agency Power 3" Single Outlet Exhaust
Between 2100-2600 Rpm, There is a weird kind of buzzing noise, maybe a rattle? I am not sure, but it only happens in THAT rpm range. I have heard of this happening to other Z's but have never seen a solution or an ACTUAL cause. I am sure with some more research i could find thread after thread about this but i still figured I would make my own haha. anyway, any information would be helpful
Old May 3, 2012 | 04:51 PM
SmoothZ's Avatar
SmoothZ
Senior Super Moderator
It's your resonated test pipes. They all make that sound, especially if you're off-load and letting the engine brake itself.
I would suggest you tighten all the exhaust bolts as best you can. Do you have new gaskets?
BTW, wrong forum section.
Old May 3, 2012 | 05:00 PM
jerseystyle's Avatar
jerseystyle
Moved.
Old May 3, 2012 | 05:18 PM
Vandy-Z's Avatar
Vandy-Z
I am getting it up on a lift next week and I will check all my bolts. I put new gaskets in it when i did the exhaust. Is there any way to make this noise go away? high-flow cats possibly?
Old May 3, 2012 | 05:24 PM
SmoothZ's Avatar
SmoothZ
Yes, I think HFC's will possibly make the noise either nonexistent or a lot quieter.
I've got resonated test pipes and am looking for a used set of HFC's for the right price.
Old May 3, 2012 | 05:33 PM
Arvin89's Avatar
Arvin89
I have non-resonated test pipes. Get the same noise. You learn to live with it. Its not that bad. Kind of sounds like turbo if you time it right..
Old May 3, 2012 | 06:54 PM
haha Made your own thread haha.
Old May 3, 2012 | 07:30 PM
04dg35's Avatar
04dg35
well i got a set of HFC's and they still make the noise, but prob not to the same extent you got.
Old May 3, 2012 | 07:54 PM
PikesPeakZ's Avatar
PikesPeakZ
If you are referring to rasp then most test pipes resonated or not will have rasp or drone.
I have found Berk Hi Flow cats to be extremely solid and reliable. After 3 years not one CEL or any issues with them. Great sound, no drone or rasp, loud as **** at WOT.
Old May 3, 2012 | 08:20 PM
Vandy-Z's Avatar
Vandy-Z
There is no rasp to my exhaust, i will try to post a video so you all can here it lol. it sounds like a really fast tick or something close if that makes sense. my initial thought was a possible rattle of some sort, but i cant pinpoint anything.
Old May 3, 2012 | 08:31 PM
Vandy-Z's Avatar
Vandy-Z
http://www.youtube.com/watch?v=-pbdx5eDyRE
my exhaust makes this same noise in the same RPM range, my exhaust mods are listed at the top of this thread. this is just a link to a video with the same noise my 350z is making.
Old May 3, 2012 | 09:31 PM
PikesPeakZ's Avatar
PikesPeakZ
It sounds like a hiss as if it is sucking air or potential exhaust leak. Prob want to re-check all connections and gaskets.
Old May 4, 2012 | 02:18 AM
Jairen's Avatar
Jairen
That hiss is normal for test pipes.
Old May 4, 2012 | 02:55 AM
CircleHeartX's Avatar
CircleHeartX
Normal*...if it was a leak you would hear it wile he is on the throttle...my borla dose that in the H pipe..did it before i got test pipes and now dose it louder with test pipes .
Sounds good wile i am on the throttle so i Guess ill live with it.
Old May 4, 2012 | 08:45 AM
bmccann101's Avatar
bmccann101
yea no sh#t right?^^.. thanks OP for adding more crap to the read after thread after thread after YOUR thread.. we certainly apprecaite your contribution, this way theres even more BS for ppl who do want to search to sift thru.. i cant STAND that.
.. now GTFO.
Old May 4, 2012 | 09:24 PM
Vandy-Z's Avatar
Vandy-Z
thats kind of what i have been reading... but will it go away with hfc?
Old May 4, 2012 | 10:29 PM
F2CMaDMaXX's Avatar
F2CMaDMaXX
It won't go away, no, in some cases it's worse.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
