Best Test Pipes??
Old Jan 7, 2004 | 05:51 AM
TourBlueZ's Avatar
TourBlueZ
Default Best Test Pipes??
I am looking for test pipes but I'm not sure which to purchase. Is there much of a difference between brand "A" or "B"? Any information is greatly appreciated.
Also I have seen numbers in the range of 10-15 HP increase. Is this accurate??
Old Jan 7, 2004 | 06:30 AM
toykilla's Avatar
toykilla
i have CAI and test pipes.. i dynoed 15 hp over stock.. i would imagin the only difference in some would be the build quality.. diameter varies a little bit but not by much
also some are titanium which is cool but a little expensive
Old Jan 7, 2004 | 08:37 AM
TourBlueZ's Avatar
TourBlueZ
Thanks toykilla. What brand are you using?
Anyone have the XERD test pipes? Do they still have the raspy sound to them?
Old Jan 7, 2004 | 08:45 AM
lsdunique's Avatar
lsdunique
We still do test pipes, and have sold dozens on this board.
Full stainless construction, mandrel bends, TIG welded, and include hardware.
Old pricing, $220
new pricing, TBA when we officially open our website for order placement.
You can also PM for new pricing if you cant wait.
Old Jan 7, 2004 | 09:22 AM
toykilla's Avatar
toykilla
i am using lsdunique's pipes.. great quality... there is a raspy sound.. i think all test pipes will have this sound.. the sound is said to be caused my more airflow smacking into the muffler ? seems like a good explanation I think my car sounds good
Old Jan 7, 2004 | 10:38 AM
PoWeRtRiP's Avatar
PoWeRtRiP
I have the xerd and they are very raspy and loud, i have a cai and a removed resonator so anything above 4k rpms is very loudand raspy.
Old Jan 7, 2004 | 11:11 AM
dduck44's Avatar
dduck44
Go with LSD's, the price is right and quality is great.
Old Jan 7, 2004 | 02:08 PM
supra crazy's Avatar
supra crazy
lsdunique
what is your new price?
Old Jan 20, 2004 | 10:58 AM
TourBlueZ's Avatar
TourBlueZ
Bought the XERD pipes and all I can say is that I should have done this a long time ago. The sound is great! As for HP gains, I haven't dynoed the car but I can say that it seems (may be in my head) that it accelerates quicker/smoother to some degree (nothing huge). I went with these b/c they have an addtional bracket (like the stock cats) that helps support the system and it was priced about the same as competitors.
Just wanted to spread the word about these test pipes.
I have the Stillen cat back and the JWT Pop charger which add to the sound!!
Old Jan 20, 2004 | 12:36 PM
lsdunique's Avatar
lsdunique
I understand the decision based on the brackets, it only makes sense!! We are adding our brackets to the test pipes as well. (we already supply them on all our high flow cat options)
There won't be any performance difference between one brands test pipes and anothers so you cant really go wrong.
Old Jan 20, 2004 | 02:16 PM
jabroney12's Avatar
jabroney12
LSD, im deciding between your high flow cats and test pipes with resonators, which gives a better hp boost and which doesn't smell as bad. They are like 10$ difference so I want to know which wil fit me better in terms of these characteristics.
Old Jan 20, 2004 | 02:34 PM
alan milford's Avatar
alan milford
Old Jan 20, 2004 | 02:38 PM
alan milford
hi when fitting the test pipes did your engine managment light come on as im told it can like to no cheers al
Old Jan 20, 2004 | 02:56 PM
FLY BY Z's Avatar
FLY BY Z
the Z has been able to handle the test pipes with no CEL so far. there have been a couple cases where the light lit but it turned out to be installer error.
Old Jan 20, 2004 | 05:14 PM
lsdunique's Avatar
lsdunique
The test pipes with resonators will give you the most in performance due to the straight through design. The high flow cats will show great performance, with zero negative emissions effects. The pipes with resonators will have that un burnt fuel smell.
If you plan on going FI in the future, I would go test pipes with resonators, if you plan on staying NA, then the high flows are the way to go.
And no they do not throw a CEL.
Old Jan 29, 2004 | 11:39 AM
ChrisMCagle's Avatar
ChrisMCagle
Default which for me?
I still have stock exhaust and am trying to decide between test pipes and hi flows. What would be the benefit of test pipes over hi flow cats with stock exhaust? Also, would I notice a difference in sound with either and the stock exhaust? I see on your site, that you have "Test Pipes with Resonators"? What would those do/not do that the regular test pipes would?
-Chrismcagle
Old Jan 29, 2004 | 11:52 AM
jabroney12's Avatar
jabroney12
TEst pipes with resonators eliminate the raspiness.
Old Jan 29, 2004 | 12:00 PM
350zdanny's Avatar
350zdanny
I can attest to the quality of LSD's test pipes and I had one of the first pairs. They fit great and seem to make power.
I think, if you have the money, test pipes with resonators is the way to go. As long as you're not in stop and go traffic, the pungent smell of the exhuast will not bother you. I was in NYC a couple times though, and my friends have complained from the passenger seat about it during idle in rush hour traffic.
Chris -
You would notice a huge difference in sound, and there would be raspiness between 3k and 4k rpm if you don't choose the resonator option. It was livable for me, but annoying. Apparently, the stock exhuast flows pretty well, so changing out the cats would still net you a hefty gain, and you might free up a couple more HP if you change out the exhaust or headers down the road.
Dan
Edit - oh and the CEL did come on for me when i used 89 octane gas or less, but I put 94 in my car anyway so that wasn't an issue.
Old Jan 29, 2004 | 02:09 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
RT Cats show more gains then test pipes...
to prove.. before my accident i put test pipes on my car... took it to the track... lost high end power... gained low end torque...
i say go with RT Cats..
special price from http://www.mynismo.com
Old Jan 29, 2004 | 02:52 PM
teh215's Avatar
teh215
If the test pipes are "raspy" on a NA car, does it get worse with a supercharger installed. My guess is yes since the volume of air has increased. Anyone have a SC and test pipes?
