Oxygen Sensors and Test Pipes
Old Aug 10, 2012 | 12:11 PM
TheWoods's Avatar
TheWoods
Default Oxygen Sensors and Test Pipes
Hey folks, just installed test pipes and now that pesky CEL comes on even after clearing the codes.
If I delete those sensors (unplug them from the connectors) will that keep the light off after clearing the codes?
OR
Is there a dummy sensor that tricks the computer?
Thanks!
Old Aug 10, 2012 | 12:43 PM
Duckeee's Avatar
Duckeee
you need non foulers
and no, don't unplug them. they are there for a reason. you'll alter the reading.
Old Aug 10, 2012 | 01:35 PM
TheWoods's Avatar
TheWoods
Non foulers?
Old Aug 10, 2012 | 02:00 PM
Duckeee's Avatar
Duckeee
research. its your friend
http://lmgtfy.com/?q=test+pipe+none+fouler
otherwise
https://my350z.com/forum/engine-driv...-fix-pics.html
Old Aug 10, 2012 | 05:52 PM
JCITY's Avatar
JCITY
Just a comment that relates to the OP's problem and others...
How many times does someone post a "in trouble" message wanting to
find a way out of a problem.These are usually DIY situations.Seems if
you don't have the needed expertise,proper tools etc,.it may be better
to take your car to a shop that does these mods on a daily basis.For sure,
its gonna cost you for the labor,but you'll prolly get the job done right.
Awhile ago,I had some HFC's installed.I could have tackled the job.However,
I did'nt have the tools,the experience on what I may have run into.Furthermore,
to waste a entire weekend trying to get it right,possibly busting a bolt or two,
listening to my wife complain...was not worth it.I took it to Z1 Motorsports.
Cost me $100 labor.Everything works like a charm.No codes to worry about,just a job well done.
Man,life is too short.
Work smart.
Old Aug 10, 2012 | 08:09 PM
thisishk350's Avatar
thisishk350
how about an uprev tune to allow the ecu to actually run correctly?
Old Aug 10, 2012 | 08:36 PM
DFW Z33's Avatar
DFW Z33
I am salad
OR
Thanks!
Dummy sensor: https://my350z.com/forum/engine-driv...ete-guide.html
Old Aug 11, 2012 | 02:57 PM
Esser's Avatar
Esser
Do not unplug them. You'll throw the same code and will then have to find something to plug the hole. Either pack the hole with steel wool or buy a 02 bung. I am running 02 non Foulers on mine and they work like a charm. Haven't thrown a code in like a year
Old Aug 11, 2012 | 06:29 PM
TheWoods's Avatar
TheWoods
For the smart *** at the top,
I did do my research and the search engine for this forums is a joke.
For the other guy, when I was doing RESEARCH some sayed fouler set up would make your car run lean. Have you noticed performance difference?
Old Aug 13, 2012 | 08:08 AM
Duckeee's Avatar
Duckeee
with that kind of attitude you wont last long here
Old Aug 13, 2012 | 09:10 AM
terrasmak's Avatar
Post cat O2 sensor only tell the ODB2 part of the ECU that the Cat is working fine
Old Aug 13, 2012 | 09:53 AM
Z33Garage's Avatar
Z33Garage
The sell 02 extenders at any autoparts stores. They are like 4-5 bucks or something each.
Buy 4 ( 2 for each side)
Install em, and add the sensors.
ECU Reset
Drive into the sunset!
Old Aug 13, 2012 | 10:59 AM
TheWoods's Avatar
TheWoods
ECU Reset
Did the non fouler set up and so far no codes. Thanks for the info.
Old Aug 13, 2012 | 11:01 AM
TheWoods's Avatar
TheWoods
I just dont like **** heads. And unfortunately about 50% of Z owners are. :/
Old Aug 14, 2012 | 05:02 AM
BoomerZ33's Avatar
BoomerZ33
Old Aug 14, 2012 | 05:18 AM
herrschaft's Avatar
herrschaft
This might get interesting...
Old Aug 14, 2012 | 06:27 AM
thisishk350
Inbeforethenoobgetsownedforbeinganasshat
Old Aug 14, 2012 | 06:37 AM
Z33Garage's Avatar
Z33Garage
Werent we all newbs once too?
Old Aug 14, 2012 | 11:14 AM
TheWoods's Avatar
TheWoods
No need to get upset, I was only speaking truth. Back on topic shall we?
Old Aug 14, 2012 | 11:17 AM
Z33Garage's Avatar
Z33Garage
^ I think OPs issue was already fixed.
