Help Anyone? =/
Old Feb 1, 2013 | 07:27 PM
RedLine_ZR's Avatar
RedLine_ZR
Default Help Anyone? =/
Ok so yesterday I installed my Jwt pop charger.. I disconnected the battery did the change and connected the battery back up.. This morning it started up fine and went to get a haircut (~15min drive) after I was done I noticed the car started and almost turned off... Rpms went low but came back up to normal.. When I got home I turned it off and back on but it turned off by itself.. I then tried turning it on the and gave it a little gas and it stayed normal.. Any help or ideas as to how to fix the problem?
04 roadster stock besides the Jwt pop charger now
**cold starts its fine just when I start while hot it will do this
Old Feb 1, 2013 | 07:35 PM
Bmurray350z's Avatar
Bmurray350z
make sure the hose that connects to the back of the intake pipe is all the way one. check the maf also.
Old Feb 1, 2013 | 07:46 PM
RedLine_ZR's Avatar
RedLine_ZR
I checked it earlier to see if everything was tight seemed fine.. Might double check again in the am but abt checking the MAF. Do you mean check that it's plugged in right which it is.. If not then what else?
Old Feb 1, 2013 | 08:21 PM
freddys 350z's Avatar
freddys 350z
the small hose that connects to the bottom side of the intake pipe.
myork's Avatar
myork
That is normal as the ECU is learning to adjust to the extra air. Give it a few days and it will stop.
Old Feb 1, 2013 | 09:59 PM
amr_electron's Avatar
amr_electron
I remember mine did the same thing after installing an Injen intake, Doing a reset took care of the problem.
Reset procedure,
Old Feb 1, 2013 | 10:03 PM
Z_on_TE37's's Avatar
Z_on_TE37's
Just google official ecu reset for 350z. Follow all 3 procedures, then it'll run perfect.
