DYNO Kinetix Velocity Manifold VS MD 5/16th spacer
Old Sep 1, 2013 | 08:57 AM
  #41
Shin Beats's Avatar
Shin Beats
I only lose 4 HP from peak to redline...the V+ loses a lot more.
Old Sep 1, 2013 | 09:09 AM
  #42
David_2613's Avatar
David_2613
Edit: I'm confused. BRB.
Okay, back. Lost track of what graphs went with which manifold.
I am really liking the power curve of the Kinetix Velocity. I would gladly give up 5hp over a 1K rpm range vs losing over 25hp as you near 7200 rpm. There's a real difference in overall power there and extending the power range like that has great dividends. I can only image that adding cams to an N/A setup would greatly benefit from this smoother flow pattern.
How are these Velocity manifolds performing / holding up under boost?
Old Sep 1, 2013 | 09:26 AM
  #43
David_2613's Avatar
David_2613
The Motordye Mrev2 lower plenum appears to help, losing on 15HP from peak to redline.
I took this dyno chart from a well tuned vehicle in this thread:
https://my350z.com/forum/tuning/5558...-t-tuning.html
Old Sep 1, 2013 | 12:24 PM
  #44
waldo36's Avatar
waldo36
What I think is unique about this graph though, the peak is closer to 5900-6000 than the other graphs showing around 6200-6300. Wonder why is moved the peak backwards?
Old Sep 1, 2013 | 04:01 PM
  #45
David_2613's Avatar
David_2613
^ More than likely a function of whoever was tuning it; and it's a solid tune. It's relatively flat from 5750 - 6250, so "peak" isn't dramatic for him. If you look at the previous run, the peak is where you would expect it.
Old Sep 1, 2013 | 04:05 PM
  #46
2004Black350z's Avatar
2004Black350z
Exhaust Whore
I think im going to try this plus 75mm tb and custom 3-4" intake. Trying to find the manifold cheap. I onky see z1 any more suggestions
Old Sep 1, 2013 | 05:41 PM
  #47
waldo36's Avatar
waldo36
That makes sense. I guess I would rather a mound of power than a peak...ya.
Old Sep 2, 2013 | 04:12 AM
  #48
Shin Beats's Avatar
Shin Beats
You will not find this manifold cheap lol. I had to pay $600..and that was used!! Someone else was selling there's on here for $500..but they flaked.
Old Sep 2, 2013 | 05:15 AM
  #49
2004Black350z
Exhaust Whore
If I can sell my powder coated black plenum 5/16 spacer and tb 4 400 ill b happy
Old Sep 2, 2013 | 05:32 AM
  #50
Bmurray350z's Avatar
Bmurray350z
Jay I saw one of these velocity manifolds used on c/l for $500 recently i think. just gotta remember what city it was in
Old Sep 2, 2013 | 06:26 AM
  #51
2004Black350z
Exhaust Whore
Supposed theres diff versions
Old Sep 2, 2013 | 07:07 AM
  #52
David_2613's Avatar
David_2613
Yeah, and I guess Kinetix isn't being too helpful in telling the difference between the models. Unfortunately they didn't use serial #s either.
What size is the intake pipe on these things? I think the stock throttle body bolts right up? Does that mean that a larger TB like the 75mm & 80mm is larger in diameter than their pipe?
I was considering building a modified stock intake similar to SG's, but I do like the idea of lower intake temperatures and the drop in weight. Both are considerable amounts.
If I were to build a modified manifold similar to SG's, it would be a design I could have produced here in the DFW area to sell as a Non-Profit item for the community.
Old Sep 2, 2013 | 07:25 AM
  #53
1cockyZ's Avatar
1cockyZ
The Velocity manifold uses 3" .065 wall pipe to the throttle body flange. This equates to 73mm ID. The ID of the 75mm tb adapter is 73mm, so perfect fit. Sorry for trolling and offering this useless information.
Old Sep 2, 2013 | 09:27 AM
  #54
Shin Beats's Avatar
Shin Beats
Yeah there's a velocity and a SSV. Don't get the SSV. The velocity manifold wont say SSV on it and only has 3 ports on the back of it.
Old Sep 2, 2013 | 03:42 PM
  #55
2004Black350z
Exhaust Whore
guess what daddy bought.......
Old Sep 2, 2013 | 03:46 PM
  #56
RUNWDVL's Avatar
RUNWDVL
The final season of Entourage?
Old Sep 2, 2013 | 04:18 PM
  #57
2004Black350z
Exhaust Whore
lmao The manifold. 3 ports on back just has kinteix on top
Old Sep 2, 2013 | 04:21 PM
  #58
RUNWDVL's Avatar
RUNWDVL
Make sure you give us a report.
Old Sep 2, 2013 | 04:26 PM
  #59
2004Black350z
Exhaust Whore
Well this just delayed my valve cover fix. However Bmurray found me a hella deal that I had to buy. What I paid saved me over 400$. WHich will pay for the NWP 75mm TB. So the dyno will show before with bad oil leak and 4-5 Spark plugs firing with bolt ons and PPEs. THen several several months later No oil new plugs and no md spacer and this manifold. Then the TB. maybe a few pulls on manifold then reutned. Then off with old TB on with 75mm. Maybe 2 runs then retune
Old Sep 2, 2013 | 05:01 PM
  #60
1cockyZ's Avatar
1cockyZ
What engine will you be doing this on? Stock cam de, revup? Will be very nice to see this test. What kind of timeline until this happens?
