JIC y pipe
Old Jan 27, 2004 | 10:04 AM
KISS's Avatar
KISS
Default JIC y pipe
I just got the JICy-pipe.
my question is, the 2 pipes are2.5 inches, they go into a 3 inch collector. my exhuast pipe is 2.5 inches. the two flanges meet up fine, but will the step up in size be ok? I've asked a few people and they said it would be alright, don't worry.
Old Jan 27, 2004 | 10:10 AM
PhoenixINX's Avatar
PhoenixINX
Default Re: JIC y pipe
If the exit is 3" and your exhaust is 2.5" these won't mate up, and this will not work.
Are you measuring internal or external piping?
Old Jan 27, 2004 | 10:17 AM
KISS's Avatar
KISS
The performance Nissan site sais it is ok. Internal
Old Jan 27, 2004 | 10:40 AM
fdao's Avatar
fdao
It will meet up, but you won't maximize your flow as you're flowing into a smaller diameter.
Old Jan 27, 2004 | 02:40 PM
zillinois's Avatar
zillinois
You might consider a 3" cat-back exhaust. Or you can just get a Japtrix mid-pipe (b-pipe) which is 3" diam. to the muffler. This is the route I went. That way it will match up. It probably won't destroy your car to run the 3" collector pipe into the 2.5 rear pipe, It just won't be ideal. (or "it" won't be ideal oops)
Old Jan 27, 2004 | 02:43 PM
fdao's Avatar
fdao
Originally posted by zillinois
You might consider a 3" cat-back exhaust. Or you can just get a Japtrix mid-pipe (b-pipe) which is 3" diam. to the muffler. This is the route I went. That way it will match up. It probably won't destroy your car to run the 3" collector pipe into the 2.5 rear pipe, I just won't be ideal.
Yup, that's my current set up. No problem thus far. Will be swapping the Japtrix Y-Pipe for the JIC soon.
Old Jan 27, 2004 | 02:54 PM
zillinois's Avatar
zillinois
Anything wrong with the Japtrix Y-pipe? I have the Ultimate racing y-pipe.
Old Jan 27, 2004 | 03:21 PM
fdao's Avatar
fdao
Nah, nothing wrong with the Japtrix. For the money, you can't beeat it, but it was time for a change. I wanted to try a slightly different design.
Old Jan 27, 2004 | 07:09 PM
F2dmfine's Avatar
F2dmfine
Hey fdao,
I sure hope you make that swap SOON!! LOL
Old Jan 28, 2004 | 06:53 AM
KISS's Avatar
KISS
Actually I measured the collector, it is not 3 but 2.75. So my 2.5 exhaust pipe won't be that bad. A eighth of an inch is not bad.
Old Jan 28, 2004 | 03:50 PM
Z33@TOR's Avatar
Z33@TOR
will the JIC y-pipe matches the stock exhaust in terms of piping size?
Old Jan 29, 2004 | 02:27 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
it will be fine... but... the flow wont be as good as if it were on a stock exhaust...
you will still get gains... pleanty of them...
Old Jan 30, 2004 | 09:48 PM
Z33@TOR's Avatar
Z33@TOR
so you mean i will still get gains from the JIC Y-Pipe if i keep the stock exhaust rite?
Old Jan 30, 2004 | 10:05 PM
OCG35Coupe's Avatar
OCG35Coupe
That Y-Pipe is so sexy for some strange reason...
Old Jan 30, 2004 | 10:42 PM
fdao's Avatar
fdao
Yup. JIC or any of the other available Y-Pipes currently being offered.
Old Jan 30, 2004 | 10:47 PM
Z33@TOR's Avatar
Z33@TOR
thx frank, so you have the stock exhaust with the y-pipe too?
i have the JIC but i have a leak at the connection point, haven't have time to fix it yet since the car is still asleep during the winter
Old Jan 30, 2004 | 10:56 PM
fdao's Avatar
fdao
WHA? A leak? Nooooo! I assume you have a gasket at the connection point? What connection point are you talking about?
Old Feb 2, 2004 | 07:52 PM
Z33@TOR's Avatar
Z33@TOR
the point that connects the stock exhaust to the y-pipe
i do have the gasket installed, but there's still a leak
Old Feb 2, 2004 | 10:08 PM
Phatmitzu's Avatar
Phatmitzu
How do we fix the leak?
Old Feb 22, 2004 | 04:48 PM
drew703's Avatar
drew703
*bump*
I'm probably going to be buying the JIC y-pipe soon, and I just came across this thread. So is there any word or more info about this leak? Do others have this problem as well?
Jason@Performance, any thoughts?
Also, who sells the Japtrix mid pipe?
Thanks in advance
-drew
