Purchased Invidia Gemini Exhaust New --
Old Feb 1, 2014 | 08:00 PM
Chromatic's Avatar
Chromatic
Default Purchased Invidia Gemini Exhaust New --
Decided to make a new thread and let the other one where I was trying to get help deciding fall off the page,.. As I've pulled the trigger and decided that I wasn't going to find a Nismo S Tune used soon (I gave it roughly two weeks.. had two deals get sold out from under me.. so said meh..)
So I kept looking and reading about all the exhausts you guys recommended,.. and for roughly $200-$250 more I couldn't resist the BRAND new Invidia Gemini True Dual Exhaust with Titanium Rolled Anodized Tips. No rust,.. made well, all new nuts, bolts, gaskets, etc. Haven't read a single bad review about it .. so it's done.
Anyhow.. The reason for the post isn't just to say what I bought.
It's on installation. I've gone over the wiki,.. and read posts I've searched up...
Here's the thing -- I'm fine with installing it myself.. I've already done much more difficult projects on the car in the last 8 weeks..
But,.. I'm hearing that the exhaust bolts/nuts are likely to be Rusted together/seized and/or impossible to break free with a wrench/socket ratchet,.. especially doing it with minimal room under some jack stands.
Just wanted some of your first hand experience installing your exhausts on a car with similar year and mileage (Mine is a 2008 350Z with 27k miles).
I don't have tools to get a bolt out that breaks on me .. I don't have a breaker bar.. and have been told I couldn't really use one with the little space I have to work with under jack stands.
I will be doing this solo.. no help. The process itself is simple.. unbolt, remove from hangers.. and I am going to assume putting the new exhaust on will be easier than taking the old off.
It more likely the nuts/bolts will be rusted/seized/ or otherwise impossible to break free at some point in taking the old exhaust off? Or is that more of a low percentage occurrence? This car has been in the Southeast it's whole life.. So it has rust, but not Salted roads or Florida type rust.
I ask because I don't want to get under the car and get stuck with no options in them middle of it.. So have to make a decision if I should do it myself based on the likelihood/chance I can get all the nuts/bolts off the old exhaust with a socket/wrench -- Or get stuck on one of the bolts/nuts.
I am not asking the impossible,.. for you to tell me one way or the other, that's obviously impossible to know. Just from those who have done this on a similarly aged/mileage 350,.. what you experienced.
Thanks
Old Feb 1, 2014 | 08:43 PM
tkuntz's Avatar
tkuntz
I think you might be worrying to much! I have an 07 nismo and put the gemini true dual on mine, mind you i had 15k miles on it when i changed mine.
What i found to help was put the car on jack stands and then spray all the OEM bolts with a rust penetrator to help the process.
This is what i used. Spray it on and let sit for a couple hours and then start tearing it apart!!
http://www.brodi.com/electrical/5in1/
Old Feb 1, 2014 | 08:55 PM
07maximan's Avatar
07maximan
Super easy. Don't overthink it. I can do it by myself with a jack and simple hand tools. Some of the bolts might be tricky but with a little persuasion will come off. You can do this!!!
Old Feb 1, 2014 | 09:53 PM
Emski's Avatar
Emski
Just buy a breaker bar then if you don't have one. And use a kinetic persuader.
Old Feb 1, 2014 | 10:05 PM
Chromatic's Avatar
Chromatic
Thanks for the reply's.. I am on several 350 forums.. And the replies on the other forums are the opposite of what you guys have said, which is the only reason I asked. Most of them said after 6 years some of the bolts are likely to be seized/rusted up, etc..
This is a simple procedure,.. it's harder to change your reverse bulbs frankly.. It's just X number of bolts, and getting it out of the hangers. The only issue I was asking about is bolts that are seized/stuck.
I'm not overthinking lol.. you guys are funny, just because someone asks a question about an exhaust install and others experiences who have done it on a 6 year old vehicle doesn't mean they are overthinking. Every job I have done on this car so far has worked first time because I've done my homework which equates to "overthinking"
Appreciate the advice,.. I'll have a look at that particular lubricant you linked.
Old Feb 2, 2014 | 04:03 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Pb blaster on bolts. Let sit for 30 mins. Then use the Pb blaster to help.persuade the hangers out and in for old new exhaust. Very very easy. IV done it at least 17 times. Lol
Old Feb 2, 2014 | 04:43 AM
Chromatic's Avatar
Chromatic
Roger! Pb seems to be THE lubricant of choice across the board.
Old Feb 2, 2014 | 05:30 AM
SmoothZ's Avatar
SmoothZ
Senior Super Moderator
I would highly recommend having somebody help you instead of being alone and doing it. It's just a safety issue, plus it helps to have someone there handing you tools or giving you a break when you get frustrated with a bolt or 2.
Old Feb 2, 2014 | 06:57 AM
travlee's Avatar
travlee
Master
woot woot, you will like the exhaust and it is very easy to install. i put mine on with my nephew when i was around 40k miles and i didnt have any isssues with the cat bolts, didnt even use pb blaster. my suggestion is go to harbor freight and get another set of stands and get the whole car up in the air
Old Feb 2, 2014 | 07:08 AM
SmoothZ's Avatar
SmoothZ
Where did you guys get your exhausts? I've been shopping around for this one and want to pull the trigger in a few months when it's warm enough for me to get under the car again.
Best prices I've found so far are just under $900 shipped from several eBay stores and vendors.
Old Feb 2, 2014 | 07:15 AM
travlee's Avatar
travlee
Master
i reached out to Gordon at invidia and he referred me to his top retailer, dont remember who it was though. the place i bought my tdx2 from also has the gemini, and what i like about them is everything is free shipping, even the tdx2
http://www.b2autodesigns.com/index.p...4fa2233fd6b100
Old Feb 2, 2014 | 07:17 AM
SmoothZ's Avatar
SmoothZ
Same pricing I'm seeing?
Old Feb 2, 2014 | 07:20 AM
travlee's Avatar
travlee
Master
i think it was around 950 shipped when i bought, check out b2, they have it for 910 and they should do free shipping. my past experiences with them is everything is drop shipped directly from manufacturer
i have always dealt with adrian there
Old Feb 2, 2014 | 08:13 AM
Chromatic's Avatar
Chromatic
I actually ended up using the Vendor here on this Forum.
Kyle of ImportPartsPro gave me a great deal on the Invidia Gemini System new,.. No one else on the Net could match his price.
This guy:
https://my350z.com/forum/members/117...tpartspro.html
Old Feb 2, 2014 | 08:15 AM
Chromatic's Avatar
Chromatic
If you are after the Invidia Gemini,.. Kyle here can beat the prices you are seeing.. He can definitely come under $900 shipped in the US.
Give him a PM,.. see what he can offer you.
Old Feb 2, 2014 | 09:56 AM
SmoothZ's Avatar
SmoothZ
Thanks guys. I believe I was looking at his site the other day when I came across his thread. So far, I think his prices are the best I've found.
Old Feb 2, 2014 | 12:01 PM
tkuntz's Avatar
tkuntz
I picked mine up though JM Auto racing, one of the vendors that posts on here.
And being that im in canada i paid $1150 shipped to my door with customs so not to bad i thought.
Old Feb 3, 2014 | 04:31 PM
Chromatic's Avatar
Chromatic
Kyle at ImportPartsPro KILLS the other prices.. at least he did for this exhaust. I'm talking by $100+ shipped lower than other places.
Are you looking at the same exhaust.. Invidia Gemini? if so.. PM ImportPartsPro and tell him I sent you. (Kidding on the sent you part.. he's well established on this forum). But he'll give you a fantastic deal and ships immediately.
IE: Ordered mine, and it will be here Wednesday.. Shipping Monday arriving Wednesday is pretty good for a heavy and huge exhaust system,.. I may be closer to where it's shipping from and that's why the such a quick turnaround.. but still I think he has quick shipping to anyone in the US.
Old Feb 3, 2014 | 04:33 PM
SmoothZ's Avatar
SmoothZ
Thanks, I will. I'm waiting for winter to be over. My garage is so full right now that I'd have no place to put anything, and I'm sure having the exhaust in my house would be so damn suspenseful it would drive me crazy just looking at it.
Old Feb 3, 2014 | 04:34 PM
Chromatic's Avatar
Chromatic
Which exhaust system was it? $1150 isn't bad for the Invidia Gemini going out of the US,.. especially if you ordered a year or more back when the prices might have been slightly higher.
Let's just say IN the US,.. I got mine , brand new,.. shipped for Under $850,.. now, I'm sure depending on where you are in the US is going to effect the shipping and total price.. I have a feeling I'm somewhat close to where it's coming from as shipping was $35.. and for 2nd Day Air on a Cat back dual exhaust system (has to be huge boxes) and weigh a ton.. that's cheap imho.
