DYNO NUMBERS ARE IN !!! Crawford package, JWT Cams, Pop Charger, Borla TD ...
Old Feb 1, 2004 | 11:50 AM
  #41
phile's Avatar
phile
Originally posted by 350trackz
smeel, noise, and legal reasons.
Probably would have, but these cams limit low end torqu enogh...i need a little backressure so i can get going.
Don't highflow cats also get rid of backpressure?
Old Feb 1, 2004 | 12:00 PM
  #42
350trackz's Avatar
350trackz
yes, but not as much as open pipes.
Old Feb 1, 2004 | 12:07 PM
  #43
TXREFI's Avatar
TXREFI
Are you saying the new cam reduce your low end torque?
I am trying to obtain more low end torque. As a newbie to import the lack of off the line torque has been my ONLY disappointment.
What can I do to improve off the line torque? I have a 2003 G35, auto, with performance wheel and tire package, which gives me the limited slip rearend.
With my corvettes we could add a lower gear rear end or beef up the torque convertor.
Old Feb 1, 2004 | 12:23 PM
  #44
kvjacobz's Avatar
kvjacobz
Aren't you getting the most torque for a NA? That says a lot about the Nissan ECU and the Crawford headers.
Old Feb 1, 2004 | 12:47 PM
  #45
phile's Avatar
phile
I'm assuming although he has more net torque , his stock dyno curve would have higher torque at lower rpms. I wish he had a stock dyno, then we could overlay the two curves...
Old Feb 1, 2004 | 01:46 PM
  #46
iLLestJrz's Avatar
iLLestJrz
Old Feb 1, 2004 | 01:52 PM
  #47
zzzya's Avatar
zzzya
There will be a different final drive available sometime in March which will get the rpms up faster and require faster shifts, but should definately help off the line. My understanding is that the autos will require more than just the new final drive, possibly a new LSD as well. A torque converter is again a possibility as well as a valve body recalibration for the autos. 350trackz can still add pulleys to help raise the HP and TQ curves a bit across the board. Not really sure how much an ECU flash would do at this point except lifting the rev limiter and removing the speed limiter. I am really excited to still see the A/F ratio where it is at with the stock ECU. I was almost decided on some suspension mods but now I think some cams may be on the horizon.
Old Feb 1, 2004 | 02:30 PM
  #48
350trackz's Avatar
350trackz
Torque peaks at about 3750.
If you look at the following thread, you will notice his base torque is fairly flat. Then look at mine and you will notice I have a BIG dip at 2750.
https://my350z.com/forum/showthread....=baseline+dyno
Old Feb 1, 2004 | 10:33 PM
  #49
OCG35Coupe's Avatar
OCG35Coupe
How much should i expect to pay for the instalation of the Crawford Headers?
Old Feb 1, 2004 | 11:19 PM
  #50
350trackz's Avatar
350trackz
$300ish or so. It takes the better part of a day for someone who knows what they are doing.
Old Feb 2, 2004 | 05:42 AM
  #51
mpowers's Avatar
mpowers
Did the cams require new shims?
Old Feb 2, 2004 | 05:44 AM
  #52
350trackz's Avatar
350trackz
nope.
Old Feb 2, 2004 | 05:00 PM
  #53
VQ35Kompressor's Avatar
VQ35Kompressor
350trackz what do you think of the Tomei 264 cams?
Old Feb 2, 2004 | 05:10 PM
  #54
350trackz's Avatar
350trackz
Those were my next choice. The JWTs have more lift and a better reputation in my book. The 264s MAY require shims. Of the shops I talked to, half did need shims, half didn't.
sales@czp
Sep 23, 2019 03:30 PM
