Engine suffocate / choke....
Old Jul 5, 2014 | 07:35 PM
JohanW's Avatar
JohanW
Question Engine suffocate / choke....
Car loses power when accelerating, as it suffocate / choke....
This problem begins after i installed an aFe open filter kit, has replaced air flow sensor, the problems remains...
If i stop and turn Engine off for 1-2 minutes, problems goes away but will come back later when i drive..
What can it be..??
Old Jul 6, 2014 | 03:08 PM
terrasmak's Avatar
Swap back to stock and see what happens.
Old Jul 6, 2014 | 04:37 PM
bealljk's Avatar
bealljk
What do you mean it has 'replaced the air flow sensor' ?
Old Jul 7, 2014 | 12:27 AM
terrasmak's Avatar
Install the stock airbox, bring the intake system back to stock and see if the problem still exists
Old Jul 7, 2014 | 04:18 AM
JohanW's Avatar
JohanW
Ok, will try this..
Thanks.
Old Jul 7, 2014 | 04:21 AM
JohanW's Avatar
JohanW
That I bought a new sensor, still problem..
Old Jul 7, 2014 | 04:24 AM
travlee's Avatar
travlee
Master
sounds like it is going into 'limp' mode, bet you have an air leak somewhere... like terrasmak said, go back to oem and see if it still happens
Old Jul 7, 2014 | 04:44 AM
SQuaLZ's Avatar
SQuaLZ
+1 either a leak or the sensor it taking "incorrect" readings and forcing the car into limp mode.
Old Jul 7, 2014 | 04:08 PM
MonkeyMagic72's Avatar
MonkeyMagic72
What can it be..??
If you can take a picture of the car what you have installed. We may able to see and help you to resolve the issue.
Old Jul 8, 2014 | 01:30 AM
JohanW's Avatar
JohanW
Thanks all, i will sen picuture asap..
Old Jul 9, 2014 | 04:30 AM
JohanW's Avatar
JohanW
Mounted back the original intake, car runs perfect, like a "scalded rat"...
I will check for leaks on the aFe kit when i put it back, thanks all for useful info.
Old Aug 13, 2014 | 06:41 AM
JohanW's Avatar
JohanW
Default Engine suffocate / choke....
Had a bit of a hurry, the car went back into "limp mode" with orginal air intake when I took a long ride ...
After much searching I found the problem, also saw that it had been up to this forum: I had changed the tail light bulb, to an LED ..!
ECU box went "bananas", changed back to the original bulbs, now the car runs properly with the aFe intake kit.
You learn as long as you live ...
Old Aug 13, 2014 | 07:22 AM
dcains's Avatar
dcains
It's not the tail light bulbs.
Old Aug 13, 2014 | 07:32 AM
JohanW's Avatar
JohanW
Ok, explain ..
Old Aug 13, 2014 | 07:33 AM
dcains's Avatar
dcains
Explain why you think it would be the bulbs?
Old Aug 13, 2014 | 08:23 AM
JohanW's Avatar
JohanW
To make a long story short, according to the mechanic ...
LEDs volts (must have a resistance ?) sends a signal to the box / anti-spin / throttle damper, that the car brakes, causing the throttel damper closes down to 17%, car goes to "Limp mode", no error codes in the box. That is the explanation i got from the mechanic man.
Have driven the car 350 km, not a shred of an error, goes perfectly ...
Before the car went 40-50 km, then error ...
I'm no expert, but I fully believe that this was the problem.
But if you have an better explanation / solution why it goes to "limp mode"
without error code, pls tell me.
Old Aug 13, 2014 | 08:36 AM
dcains's Avatar
dcains
Several years ago I replaced every single filament bulb in my Z with an equivalent LED. Not a single issue. That's all I can tell you, but if your car is OK now, then leave it alone.
Old Aug 13, 2014 | 09:10 AM
JohanW's Avatar
JohanW
Ok, thanks..
Old Aug 26, 2014 | 08:54 AM
Riick's Avatar
Riick
?? Did the LEDs you installed also have 35-50 watt resistors wired in?
They make the car's computer see the LEDs as standard incandescent bulbs.
If not, that's your solution to having your cake & eating it too.
I got four dirt cheap (under $7) on eBay and no fuss from my car.
Just search for 4x LED Load Resistor - delivery did take maybe 3 weeks, but then again, I didn't pay $50 and up
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
