***Tomei Expreme Ti Install***
Old May 12, 2015 | 04:40 AM
jdmfetish's Avatar
jdmfetish
the Y-Ti expreme mid pipe will be here Mon-Tue next week
excited for moving forward literally toward the front
wonder if it will affect the sound over the OEM Y-pipe? anyone ?
Old May 12, 2015 | 09:34 AM
Resmarted's Avatar
Resmarted
It absolutely will. It will give the whole system a deeper tone, and the merging on that ypipe will probably give it a bit of rasp. How quickly that ypipe merges will also change the tone compared to other ypipes, as well as the material will make it have a different tone. The standing waves should resonate the material a bit differently
My expreme should be here soon as well.
Old May 12, 2015 | 10:39 AM
jdmfetish's Avatar
jdmfetish
sounds great appreciated
there any power gains to be had from Throttle Body & MAF upgrade , going to stay NA?
Lastly Keep my paper filter , or K&N drop in , JW Pop Charger , again same questions power gain to be yielded ?
Old May 12, 2015 | 10:51 AM
Resmarted's Avatar
Resmarted
IMHO TB might not be worth it on a DE. Maybe a rev up, where you can rev higher. But a DE shouldn't be taken much past 7k anyway.
A true CAI might get you some power? If I were you though I'd get a plenum spacer, testpipes/headers and a tune over everything else. If you want to go crazy on the intake, buy a methanol injection system. Pick a kit that can run 100% meth and then have the car tuned on it. It will definitely pickup power
Old May 12, 2015 | 11:21 AM
jdmfetish's Avatar
jdmfetish
great appreciated
how do i know if mine is a DE or Rev up ?
2006 6 speed
Old May 12, 2015 | 02:32 PM
Resmarted's Avatar
Resmarted
great appreciated
2006 5 speed
Where is the redline on your tach? If the little line starts at 7 you have a rev up, if it starts between 6 and 7 thousand, you have a regular DE. The rev up has more aggressive cams, and a better oil pump, so it can rev higher and will make more power up top.
Either way, the TB upgrades aren't cheap. For the money you could have a good reflash that could make more power. If you have a 5 speed, I think uprev can increase your transmission line pressure, so you should be able to get quicker firmer shifts... Which believe it or not actually helps the life of the clutch packs
Old May 12, 2015 | 03:42 PM
Resmarted's Avatar
Resmarted
I just came home, and the ups guy dropped off my expreme. It's cool.
Old May 13, 2015 | 05:44 AM
jdmfetish's Avatar
jdmfetish
congrats Bro
how much did you get Muffler , Mid , Cat pipe ?
Old May 13, 2015 | 05:46 AM
jdmfetish's Avatar
jdmfetish
thanks my redline starts at 7 K
Rev Up
Lovely
Old May 13, 2015 | 08:41 AM
SQuaLZ's Avatar
SQuaLZ
If you have a AT which I am assuming since you said you have a 5 speed, then you have a DE. Rev Up was only on the 6 speed.
Old May 13, 2015 | 08:48 AM
jdmfetish's Avatar
jdmfetish
my bad
6 speed manual
redline at begins at 7
Old May 13, 2015 | 02:21 PM
Resmarted's Avatar
Resmarted
my bad
6 speed manual
Nice you have a rev-up. If you put in a lower manifold from a DE, maybe a plenum spacer and a reflash (500$ for all if you do it right) you should see some nice gains with your exhaust. Throw in some test pipes and you're set. I have a DE lower plenum if you're interested. I can give you a good deal
Old May 13, 2015 | 05:28 PM
jdmfetish's Avatar
jdmfetish
KEWL
Mid Ti Y-pipe is arriving Mon-Tue install that Wed, I have a new in box K & N drop in filter as well put that in same time
Decided on the Ti cat delete over their SS test pipes so i will get that ordered
then i can make a decision on what exactly i am doing intake wise after the above
I will keep your offer in mind , but i may have a DE lower plenum available need to check LYK
any spacer stand out or all the same ? want to keep my strut bar
Old May 13, 2015 | 06:41 PM
Resmarted's Avatar
Resmarted
KEWL
Spacers shouldn't make a difference really. 1/2" will get a bit higher end power but the 3/8" is usually preferred. Good manufactures include spacers for your strut bar (motordyne). There are options like isothermal which "help" but if you ask me aren't worth the extra $. You're just reducing the transference rate from the lower plenum to the upper... But the upper isn't what heats the air up. The lower is.
Motordyne is a good choice. I'd reccomend that, I liked mine. Clean kit. Easy to put in. Good gains on na. Then look around for a reflash. Motordyne also has an mrev2 which is a De lower plenum machined about 5-6mm and ported. Buy mine for under a 100$ and get it machined instead :P
Old May 28, 2015 | 11:57 AM
jdmfetish's Avatar
jdmfetish
Well though i did not take pictures , we did install the Tomei Titanium Y pipe last night
it did get louder
looks great
went in very easy
going to order the Tomei Titanium Cat Pipes next week , and install them Mid -June
awesome exhaust so far
It is LOUD
Old May 28, 2015 | 03:42 PM
Conway_160's Avatar
Conway_160
it did get louder
looks great
went in very easy
It is LOUD
How loud is LOUD? I'm assuming there is a lot of drone?
Old May 29, 2015 | 06:20 AM
jdmfetish's Avatar
jdmfetish
if i had a term lab is could give you a decibel reading
so to put a number to it is something i am not able to do
I have not had it on the expressway , so can't give you a drone report
only had it up to 55 ish
but my car has 144 sq feet of Stinger Roadkill in it so it will not sound like it does in another Z
it is extremely well insulted
sorry i can't give you something more solid to go on
Old Jul 29, 2015 | 11:32 AM
  #38
jdmfetish's Avatar
jdmfetish
installed the tomei Ti test pipes
so now the test pipes , y pipe , and cat back are all in
it is very loud
but i like it
tm9293
North East Marketplace
13
Oct 17, 2015 09:14 PM
CleanFairladyZ
Sep 30, 2015 03:58 PM
