Fuel smell after installed MD ART/Exhaust
Old Sep 3, 2015 | 08:18 PM
Rubidium's Avatar
Rubidium
Originally Posted by Rev_Night
right, but i didnt know there would be an accompanying fuel smell + pops. I read that somepeople like the pops -- personally i hate them.
Im going to call Ptuning again tomorrow. Ask them if I am running rich (fuel smell + existence of pops), if we could try to run the car a bit leaner. Hopefully would remove both, and the performance hit can't be more then 1-2%
There was a user who had some High Flow Cats installed into the second to last pipes of the TDXv2, it eliminate the smell and might eliminate the "poping". When I had this set up it wasn't that bad, you'll get used to it...give it some time. The high flow cats at that point isn't going to change to much of your power but will kill the smell.
Old Sep 3, 2015 | 08:28 PM
Rev_Night's Avatar
Rev_Night
they must have been some long HFCs to perfectly fit as those mid pipes. One of them has to be bent too to accomodate the rear sway. What brand, would you recall?
Old Sep 4, 2015 | 04:44 AM
Pengu's Avatar
Pengu
OP, where are you located? I've been to PTuning and such, if you sell those ART pipes please contact me.
Old Sep 4, 2015 | 05:12 AM
Rev_Night's Avatar
Rev_Night
I'm located in the DC area. If need to sell them they are all yours, but bear in the asking price will be rather close to the MSRP. They are only 2 weeks old
Old Sep 4, 2015 | 07:15 AM
Pengu's Avatar
Pengu
Understood. How strong is the fuel smell? I always had a hint of it when I ran test pipes, XYZ pipe, and agency power single.
Old Sep 4, 2015 | 08:21 AM
Rev_Night's Avatar
Rev_Night
Enough that its annoying me, but I am kinda a perfectionist. It's also the pops that are getting to me more. Before I go to the shop, is there any reason that no cats (so fuel smell) would produce pops in the exhaust? Would that fuel smell be enough of a fuel concentration to burn up and create the noise in the exhaust? Tony at MD said that this shouldnt be happening, but what does the community think?
Old Sep 4, 2015 | 11:15 AM
Pengu's Avatar
Pengu
Doubtful, also Tony is extremely knowledgeable as his background involves rocket science I believe. What is sound exactly like? Does it only happen if you speed up and let off the gas and slow down? Any chance you could take a video? I am in the Gainesville area if you're near by.
Old Sep 4, 2015 | 11:24 AM
Rev_Night's Avatar
Rev_Night
It only happens after I speed up and then let off the gas (or shift down, or in neutral). And I wish I could show you, but it doesnt happen that much when my car is idle and just having the engine being revved (aka in my driveway).
Is running rich a problem that the dynotune should have solved? Ptuning did the tune like 2 weeks ago.
Old Sep 4, 2015 | 12:09 PM
travlee's Avatar
travlee
Master
it is because you have no back pressure, when you let off the throttle, yo have high speed gasses (from when you were on the throttle) and then lower speed gasses coming (after you let off the throttle). i THINK that the pops are the start of the slower gasses coming out.
Old Sep 4, 2015 | 01:00 PM
Rev_Night's Avatar
Rev_Night
Would running a bit leaner fix this?
Old Sep 4, 2015 | 02:35 PM
travlee's Avatar
travlee
Master
i would rather be rich instead of lean. lean will could possible lead to engine damage
Old Sep 4, 2015 | 04:53 PM
Rev_Night's Avatar
Rev_Night
How about run less rich? How much would this cost from a pro shop? Is this somethign I could do myself?
Old Sep 4, 2015 | 06:16 PM
Rubidium's Avatar
Rubidium
Here you go for Vibrants 500hp HFC
They're not that big, you can easily stagger then on the second to last pipes before the sway.
Old Sep 4, 2015 | 07:19 PM
nizmo_0385's Avatar
nizmo_0385
Op does it sound like this?
This is an s tune with stock cats and no tune.
I thought all VQ motors popped.
https://youtu.be/1xYQ1axOOE4
And the tomei with stock cats no tune.
https://youtu.be/ID2HpLSdVkI
Old Sep 10, 2015 | 03:53 PM
Rev_Night's Avatar
Rev_Night
Are they actually cutting into my exhaust? That seems a bit too much beyond the point of no return for me, esp since its $400 each + labor.
Yep, thats basically exactly what its sounding like.
Would HFCs eliminate both the smell and the pops? If so, which ones are great to match with MD TDX2?
Old Sep 10, 2015 | 04:02 PM
nizmo_0385's Avatar
nizmo_0385
Good questions. I dont know how hfc perform on the VQ but am pretty sure it will cutout the smell. As for pops mine does it with stock cats so i think there isnt much you can do aside from getting a quiter exhaust or adding resonators somewhere.
Old Sep 10, 2015 | 04:14 PM
Rev_Night's Avatar
Rev_Night
Both the test pipes and exhaust ends have resonators. Thats 4 total (2 per side). lol how many more are needed and where would they go?
Old Sep 11, 2015 | 01:05 AM
  #38
nizmo_0385's Avatar
nizmo_0385
Im sure an exhaust shop could add something. However itll kill the sweet note of tdx. I would personally put stock cats back in.
Old Sep 11, 2015 | 04:57 AM
  #39
Rev_Night's Avatar
Rev_Night
lol which I have already sold
Old Sep 11, 2015 | 04:59 AM
  #40
travlee's Avatar
travlee
Master
after a month you wont even notice the smell... if you are smelling it in the cabin my guesses is you have an exhaust leak
