O2 Sensor Question
Old Dec 19, 2015 | 12:33 PM
louisville13's Avatar
louisville13
Default O2 Sensor Question
I drive an 05 track edition z with a few light mods, including motordyne ART test pipes. After the test pipes were on for about a month my car threw the codes P1274(sensor 1) and P1146(heated o2 sensor 2). I took my car to a performance shop (which I realize was stupid) and $250 later I had a new o2 sensor and was told the code was taken care of. The next day the code came back. I took the car back to the shop and they went in and I guess disabled those two codes from being able to trip the CEL. SO things were great for a few months until today. Today my car threw the code P1283 (bank 2). I really don't want to go through the process of replacing another o2 sensor and it not working again.
So my question is, if I get this code disabled, then that means I will have 3 o2 sensor codes disabled, would I ever know if anything is wrong with my 02 sensors? And would it matter if something was wrong with the o2 sensors if the codes are disabled? Thanks for any help and sorry for the vagueness of the descriptions for the codes, those are the only things I could find on them.
Old Dec 23, 2015 | 11:52 AM
louisville13
Somebody please help. I only have enough time to take my car to the mechanic or to dynosty next week. I have to make sure i know if the o2 sensor is bad or if i just beed to remove the code.
Old Dec 23, 2015 | 12:02 PM
iideadeyeii's Avatar
iideadeyeii
I don't think you can just disable the sensors without a piggyback or uprev. All I had to do on my car was add a long o2 extender on each o2 and it didn't throw a code
Old Dec 23, 2015 | 03:51 PM
louisville13
I thought the ART pipes had an extender so they wouldnt throw a code? Do you have a link to your extenders? Thanks for the reply!
Old Jan 13, 2016 | 12:48 PM
thE33Z33's Avatar
thE33Z33
From what I've read, p1283 is a lean condition read on bank 2, sensor 1. this is the sensor that's pre-cat. If you're running lean, they should be able to confirm this when you go get tuned. Definitely wanna get that a/f fixed before you burn up a valve or something. If the sensor itself is bad, replace it with a Denso sensor. From what I've read, a lot of poepl will try and use the more common Bosch wideband replacements you can get at most auto parts stores. More often than not, the code comes again. Something about the speed at which the Bosch sensor reads compared to the Denso one. Get the Denso, I think that's what comes OEM anyway.
Old Jan 13, 2016 | 01:44 PM
louisville13
So if it's running lean that means they didn't tune it right? Because it was running fine before the tune? Ive been trying to get it into the shop but things have been a little hectic.
Old Jan 14, 2016 | 07:49 PM
thE33Z33's Avatar
thE33Z33
I'd be surprised if anybody would tune you for $250. When i say "tune" i mean they flash your ECU and put your car on the dyno and get max power out of it with the mods you have. The biggest thing here is they correct your air/fuel ratio and make it safer to drive. I went to uprev to get mine done. Be prepared, it costs a pretty penny to get that first tune.
Old Jan 14, 2016 | 08:17 PM
louisville13
I think i may have been a little unclear in my original post. The o2 sensor problems started happening after i got my car tuned. Do they have to re-tune the car to fix this? And finally got an appointment on Monday so hopefully itll be fixed then!
AJLUVHERZ
Jan 26, 2016 05:01 PM
dario417
Dec 11, 2015 02:42 PM
Flagrant Wolf
Dec 3, 2015 03:23 PM
